Hi everyone!
I know this is way off the topics discussed lately by QGIS developers
and perhaps not even a QGIS-specific question, but I would really
appreciate any insight.
Overview:
I have created a QGIS plugin with two widgets, using the plugin
template: i.e. 1 plugin menu item with two menu items. The first widget
is a simple 1-layer layout with a push-button, all in 1 group box. The
second widget has three group boxes and two separate buttons. The one
button opens another widget (with text box inputs and a save button) and
the other button starts an algorithm.
The problem:
The first widget works fine, the second, however, displays everything
double (error->dialog boxes(another on OK), button->the widget(x2)
etc.). The gui part for both widgets is logically similar and I have not
any gui objects repeated in my *.ui file.
I have included the more important code at the bottom of e-mail...
Please, I have a final project demo next Wednesday!
Schalk
Code
Plugin(.cpp):
#include "importer.h"
#include "localise.h"
void GSMLocator::initGui()
// Create the action for tool
mQImportPointer = new QAction(QIcon("plugin.png"),tr("&Import
drive-tests"), this);
mQLocatePointer = new QAction(QIcon("plugin.png"),tr("&Locate GSM
cellphones"), this);
// Set the what's this text
mQImportPointer->setWhatsThis(tr("Plugin that supports the import of
Ericsson TEMS format drive-tests."));
mQLocatePointer->setWhatsThis(tr("Plugin that provides GSM positioning
functionality from measurement reports."));
// Connect the action to the run
connect(mQImportPointer, SIGNAL(activated()), this,
SLOT(runImport()));
connect(mQLocatePointer, SIGNAL(activated()), this,
SLOT(runLocate()));
// Add the toolbar
//mToolBarPointer = new QToolBar((QMainWindow *) mQGisApp, "&GSM
Locate Tools");
//mToolBarPointer->setLabel("&GSM Locate Tools");
// Add to the toolbar
mQGisIface->addToolBarIcon(mQImportPointer);void GSMLocator::initGui()
SLOT(runImport()));
SLOT(runLocate()));
// Add the toolbar
Locate Tools");
mQGisIface->addToolBarIcon(mQLocatePointer);
mQGisIface->addPluginMenu("&GSM Locate Tools", mQImportPointer);
mQGisIface->addPluginMenu("&GSM Locate Tools", mQLocatePointer);
void GSMLocator::runImport()
Importer *imp = new Importer(mQGisApp, QgisGui::ModalDialogFlags);
imp->show();
void GSMLocator::runLocate()
Localise *local = new Localise(mQGisApp, QgisGui::ModalDialogFlags);
local->show();
Widget1 [works correctly]
-------(.h)
class Importer : public QWidget, private Ui::ImportDrive
Q_OBJECT
public:
Importer(QWidget *parent = 0, Qt::WFlags fl = 0 );
~Importer();
public slots:
int pressed_lPushbutton();
void on_pbnbuttFile_clicked();
.....(.cpp)............................................
#include <QtGui>
Importer::Importer(QWidget *parent, Qt::WFlags fl )
setupUi(this); // this sets up GUI
// signals/slots mechanism in action
connect( pushButton_lnew, SIGNAL( clicked() ), this,
SLOT( pressed_lPushbutton() ) );
connect(this,SIGNAL( nextRecord(int) ),progressBar,SLOT( setValue(int) ) );
connect( butt_File, SIGNAL( clicked() ), this,
SLOT( on_pbnbuttFile_clicked() ) );
Importer::~Importer()
void Importer::on_pbnbuttFile_clicked() {
QString myFileNameQString =
QFileDialog::getOpenFileName(this, //parent dialog
tr("Select filename of drive-test list (drive-tests must be in same
folder)"),
".", //initial dir
tr("Text file (*.txt *.fmt)"));
txtFile->setText(myFileNameQString);
Widget2
--------(.h)
// Qt functions
#include "ui_LocateGSM.h"
#include "configconn.h"
#include <QtGui>
class Localise : public QWidget, private Ui::LocateGSM
Q_OBJECT
public:
Localise(QWidget *parent = 0, Qt::WFlags fl = 0 );
~Localise();
char* join(char* s1, char* s2);
..........(.cpp)....................................................
#include <QtGui>
Localise::Localise(QWidget *parent, Qt::WFlags fl )
connect( pbnDBConn, SIGNAL( clicked() ), this,
SLOT( on_pbnDBConn_clicked() ) );
connect( pbLocate, SIGNAL( clicked() ), this,
SLOT( on_pbLocate_clicked() ) );
// enabling/disabling buttons
//pushButton_stopnew->setEnabled( false );
Localise::~Localise()
void Localise::on_pbnDBConn_clicked()
ConfigConn *conninfo = new ConfigConn(this);
conninfo->show();
--------------------------------END--------------------------------------------------------------
