[Qgis-developer] about grass plugin (windows)
Radim Blazek
radim.blazek at gmail.com
Tue Nov 28 16:48:59 EST 2006
On 11/28/06, godofredo contreras <frdcn at hotmail.com> wrote:
> Hi Radim:
> What do you think about using cmd or command instead of msys shell for
> windows version of plugin? it could eliminate the necessity of distribute
> msys shell with qgis.
IMO native cmd/command is absolutely useless. We have to use MSYS
shell, I dont see other possibility.
Radim
> Freddy
> ________________________________
> From: "Radim Blazek" <radim.blazek at gmail.com>
> To: "godofredo contreras" <frdcn at hotmail.com>
> CC: qgis-developer at lists.qgis.org
> Subject: Re: [Qgis-developer] about grass plugin (windows)
> Date: Tue, 28 Nov 2006 12:09:18 +0100
> >On 11/27/06, godofredo contreras <frdcn at hotmail.com> wrote:
> >>Hi:
> >>I have been working in a debugging environment for qgis based on :
> >>msys and
> >>eclipse cdt with some success. I was analizing grass plugin source
> >>and the
> >>notes that Benjamin posted in http://blog.qgis.org/?q=node/35. I
> >>saw in some
> >>notes in plugin code that there were some problems opening a cmd or
> >>command
> >>shell. I am very new to grass and I would know if grass shell is
> >>simply an
> >>operating system shell with grass executables in path, if this is
> >>the case
> >>we could solve the problem calling a grass.bat in qgis folder that
> >>sets all
> >>environment variables and open a cmd window, if not, could somebody
> >>tell me
> >>what is needed from a grass shell ?
> >GRASS shell is using MSYS terminal, i.e. qgis/msys/msys.bat
> >but some variables must be set previously by the plugin (GISBASE,
> >GISRC).
> >>Also I got a weird problem, I copy shared folder from a previous
> >>installation of qgis and every time a try to execute a grass
> >>command, the
> >>plugin looks for executables in the old path. Are there any
> >>configuration to
> >>set the grass executables path?
> >The plugin is looking for modules in GISBASE directory. Normaly
> >you dont need to specify the directory especially on windows where
> >it attempts to use qgis/grass directory. If a directory with GRASS
> >is not found in the expected path you are asked to select a
> >directory.
> >In that case the path is stored in QGIS settings and it is used
> >in future if the directory is valid. If that directory was removed
> >you should be asked to select another one.
> >The only way to change GISBASE if previously dir still exists
> >is to edit QGIS settings manualy.
> >Radim
> >>thanks in advance.
> >>Freddy
> >> Get free, personalized commercial-free online radio with MSN
> >>Radio powered
> >>by Pandora
> >>_______________________________________________
> >>Qgis-developer mailing list
> >>Qgis-developer at lists.qgis.org
> >>http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> MSN Shopping has everything on your holiday list. Get expert picks by
> style, age, and price. Try it!
