[Qgis-developer] re: QGIS debug version on windows
Martin Dobias
wonder.sk at gmail.com
Wed Nov 29 07:17:23 EST 2006
Erm, tried it now again with updated SVN without my hack (LIBS += ...)
and with settings.pro still set to CONFIG += release and now also
debug version of qgis.exe builds correctly - without the need to use
CONFIG +=...
I'm a bit confused with this - looking at recent commits by Tim I see
that he's been altering only providers and plugins project files, thus
I don't understand why does linking qgisapp work now :-)
Any ideas?
Martin
On 11/28/06, Martin Dobias <wonder.sk at gmail.com> wrote:
> Great, I will try it also and commit that. Looks much better than my
> solution by adding the libs manually.
> Bye,
> Martin
> On 11/28/06, godofredo contreras <frdcn at hotmail.com> wrote:
> > Hi Martin:
> > I found the problem. You only need to change line 68 of settings.pro from :
> > CONFIG += release
> > to
> > CONFIG += debug_and_release
> > It was configured to build release only.
> > Regards
> > Freddy
> > ________________________________
> > From: "Martin Dobias" <wonder.sk at gmail.com>
> > To: "godofredo contreras" <frdcn at hotmail.com>
> > CC: qgis-developer at lists.qgis.org
> > Subject: Re: [Qgis-developer] re: QGIS debug version on windows
> > Date: Mon, 27 Nov 2006 21:03:39 +0100
> > >Hi Freddy,
> > >I've downloaded qt 4.2.1 and installed it. It doesn't contain debug
> > >version of Qt libraries. So I had to run:
> > >(qt_path)\bin\qtvars.bat compile_debug
> > >to compile debug versions of qt libs as they're necessary for debug
> > >version of QGIS.
> > >When compiling QGIS application as release version, everything is
> > >fine
> > >(both libraries mingw32 and qtmain are used. But when compiling
> > >debug
> > >version linking fails because these libraries (because of some
> > >reason)
> > >are not included.
> > >I hope this describes my situation with enough details.
> > >Martin
> > >On 11/27/06, godofredo contreras <frdcn at hotmail.com> wrote:
> > >>Hi Martin:
> > >>I have been working with the old version of msys and I havenĀ“t had
> > >>that
> > >>problem, could you give us more details about the problem?. I will
> > >>download
> > >>the new msys and try to replicate your problem. Also it will be
> > >>useful to
> > >>know what version of qt you are using and if you built qt for
> > >>debug.
> > >>Regards
> > >>Freddy
> > >> Stay up-to-date with your friends through the Windows Live Spaces
> > >>friends
> > >>list.
> > >>_______________________________________________
> > >>Qgis-developer mailing list
> > >>Qgis-developer at lists.qgis.org
> > >>http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> > MSN Shopping has everything on your holiday list. Get expert picks by
> > style, age, and price. Try it!
