[Qgis-developer] GRASS gdal-grass driver under windows
Radim Blazek radim.blazek at gmail.com
Thu Nov 30 10:45:20 EST 2006
---------- Forwarded message ----------
Date: Nov 30, 2006 3:21 PM
Subject: Re: [Gdal-dev] gdal_grass.dll
To: Radim Blazek <radim.blazek at gmail.com>
Cc: gdal-dev at lists.maptools.org
Radim Blazek wrote:
> Hi.
> Where should we place the gdal_grass.dll so that gdal can find it
> and register?
Radim,
Looking at the code, it would appear that you can out plugins in a
gdalplugins subdirectory of whatever directory the current executable
comes from.  If you want to put it somewhere else, you will need to
define the GDAL_DRIVER_PATH environment variable or config variable
to point to the directory to be searched.
Best regards,
On 11/30/06, Tim Sutton <tim at linfiniti.com> wrote:
> Hi
> Ok Ill try to compile your way too under msys...
> Regards
> Tim
> On 11/30/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> > I recompiled GDAL with GRASS support, it was not stand alone module.
> > I'll ask in gdal-dev list.
> > Radim
> > On 11/29/06, Tim Sutton <tim at linfiniti.com> wrote:
> > > Hi (Radim! :-)
> > > I've build a gdal_grass.dll driver for gdal to read grass rasters in
> > > msys. What I cant work out is where in the application bundle it
> > > should go to be found and used properly at runtime? I tried looking in
> > > the xcompiled prev2 zip and dont see it ther. How did you get rasters
> > > to work in the xcompiled versions? Any other tips?
> > > Thanks
> > > Tim Sutton
> > > Visit http://qgis.org for a great Open Source GIS
> > > Home Page: http://linfiniti.com
> > > Skype: timlinux
> > > MSN: tim_bdworld at msn.com
> > > Yahoo: tim_bdworld at yahoo.com
> > > Jabber: timlinux
> > > Irc: timlinux on #qgis at freenode.net
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.qgis.org
> > > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> Tim Sutton
> Skype: timlinux
> Jabber: timlinux
