[Qgis-developer] Adding delimited text file as layer...
Radim Blazek
radim.blazek at gmail.com
Mon Oct 2 06:06:17 EDT 2006
I am just curious, are you running the application on a smart phone?
How do you read the information about BS, distance and signal strength?
Once I was thinking about it but then I found that it is not possible
to get such info in a phone, at least in java it was not.
Radim
On 10/2/06, Schalk Snyman <snymans at wbs.co.za> wrote:
> Hello,
> I have written a program to approximate the location of GSM cellphone
> users. At this moment all I really need QGIS for is to display the
> approximated points as well as the GPS points on a map (added as
> shapefile layer) - which pop-up after the calculations.
> I would like to use a comma-delimited text file X,Y to add the points as
> a layer. (It's OK if the points are in separate text files)
> I thought this would be relatively easy as this is already done rather
> easily in the QGIS 0.8 gui. However I struggle to keep my head together
> with all the gui slots and Qtishness (I'm new to Qt as well).
> I'm using Tim Sutton's "Tutorial 2: Using MapTools with the QGIS Canvas
> API" as a base point. How can I extend this code (with simple includes
> and of course on the same map canvas) to add a points layer from a
> delimited text file?
> Best Regards to fellow Developers!
> Schalk
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
