[Qgis-developer] segmentation fault in plugin using zoom tool
Martin Dobias
wonder.sk at gmail.com
Thu Oct 5 04:29:18 EDT 2006
On 10/5/06, nitin quick <quick.nitin at gmail.com> wrote:
> greetings developers,
> i am currently coding a plugin which will make use of map tools but it
> is giving me seg fault.
> Operation is such : plugin has a pointer to qgsmaptoolzoom, on
> activating action for this plugin it do
> PointTool::PointTool(QgisApp * theQGisApp,
> QgisIface * theQgisInterface):
> QgisPlugin(sName,sDescription,sPluginVersion,sPluginType),
> mQGisApp(theQGisApp),
> mQGisIface(theQgisInterface)
> zoomTool=new QgsMapToolZoom(mQGisIface->getMapCanvas(),false);
> void PointTool::okReceived()
> mQGisIface->getMapCanvas()->setMapTool(zoomTool);
> this will make zoomTool current map tool.
> Aftert this if i select tool identifyfeature, and again select
> zoomTool from plugin menu it results in segmentation fault. I couldn't
> find solution for this problem. please help me get out of it. The code
> which i put up is i think only relevant here, rest is std generated by
> plugin builder or i can put whole code.
> quickNitin
if I recall correctly, you shouldn't store map tool because the tool
is owned by map canvas and the old tool gets always deleted in
QgsMapCanvas::setMapTool. So your code should look like
QgsMapCanvas* canvas = mQGisIface->getMapCanvas();
canvas->setMapTool(new QgsMapToolZoom(canvas,false));
Hope that helps,
Martin
