[Qgis-developer] API change: map tools
    Martin Dobias
    wonder.sk at gmail.com
    Fri Oct 13 07:58:18 EDT 2006
On 10/13/06, Radim Blazek <radim.blazek at gmail.com> wrote:
> On 10/13/06, Martin Dobias <wonder.sk at gmail.com> wrote:
> > Hi,
> > according to recent debate on qgis-developer list (in thread
> > "segmentation fault in plugin using zoom tool"), I've modified the way
> > how to work with map tools (in revision 5940).
> > Till now, after setting QgsMapCanvas::setMapTool() map canvas took
> > ownership of the tool and when it was replaced with another tool, it
> > got deleted. This showed to be a bit problematic.
> > New way of using map tools is that caller must save the pointer to the
> > map tool. When you call setMapTool(), the old tool gets deactivated
> > and new tool gets activated and set as current. Later, tool has to be
> > deleted by the owner. There's no problem to delete a tool while it's
> > being still used as QgsMapTool constructor calls
> > QgsMapCanvas::unsetMapTool which stops to use that tool if it's active
> > (or saved as last non-zoom tool).
> > I hope that it won't introduce any new problems, but if so, let me know.
> Are you going to change also GRASS plugin?
> Radim
GRASS plugin and georeferencer have been updated to reflect this
change - it's in revision 5940.
Martin
