[Qgis-developer] Re: [Qgis-user] mdb files?
William Kyngesburye
woklist at kyngchaos.com
Mon Oct 30 09:10:14 EST 2006
The problem is not GDAL+UnixODBC - I realize that GDAL was written
with that in mind. The problem is that the only Access ODBC for
_OSX_ that I was able to find that operated directly on files is made
for OSX's built-in iODBC.
Nice to know about mdbtools (I might have seen it before but had no
luck with it, don't remember).
On Oct 30, 2006, at 12:21 AM, Mateusz Loskot wrote:
> William Kyngesburye wrote:
>> It is possible on OSX, but you must spend a few $. GDAL can read
>> personal geodatabases, stored in MDBs, using an ODBC driver. But,
>> you
>> must make sure that it is built with iODBC, not UnixODBC, and this
>> takes
>> a bit of patching (my GDAL framework is built this way). Then you
>> need
>> to install Actual Technologies's MS Access ODBC driver (this is
>> commercial software, but cheap).
> William,
> I can not agree.
> I've been working on PGeo driver for OGR for and it works with
> unixODBC.
> The problem is with mdbtools which behave very instable from
> version to version.
> For example release newer mdbtools-0.6pre1 doesn't work but older onw
> mdbtools-0.5.99.0.6pre1.0.20050409 does.
> I've been investigating these issues and found solution, but MDB Tools
> project seems to be orphaned because I've not got any response to my
> e-mails with my offers with fixes since 5 months.
> You can find details in following thread:
> http://lists.maptools.org/pipermail/gdal-dev/2006-May/008898.html
> and here
> http://lists.maptools.org/pipermail/gdal-dev/2006-May/008953.html
> Non-ESRI PGeo mdb files can be accessed through OGR ODBC driver.
> Here you can also see that it's possible to use OGR ODBC driver on
> Windows to connect to MDB file. I don't have any Microsoft Office
> installed.
> http://bugzilla.remotesensing.org/show_bug.cgi?id=471
> This things are supposed to work, so in case you have any problems,
> please post them on the gdal-dev list or submit appropriate bug report
> That will help us to keep GDAL reliability.
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
