[Qgis-developer] Projection parameters for french NTF
Tim Sutton
tim at linfiniti.com
Thu Sep 28 00:37:56 EDT 2006
Hi
Magnus Homann just raised a similar issue for Swedish projections.
When we created the srs.db the idea was we should not change
projections with official EPSG/PGIS ID's. The idea being that we
would update the database before a release with any upstream
corrections (coming from spatial_ref_sys table in postgis unless
there is a more official source). So this means three things:
1) we need to decide what will be the cananical source for SRS
descriptions (Im leaning towoards postgis / spatial ref sys table
2) we find a way to get suggested changes into the upstream srs
source if they originate from our users
3) we need to come up with a manageable way to synchronise the srs.db
that is distributed with qgis with the canonical srs source.
If anyone is interested to take on some or all of these aspects it
would be great. It doesnt require any coding knowledge as such and
would be a very useful contribution to QGIS. In the mean time the
best way to introduce changes to the distributed srs.db is in the
form of a simple sql update command patch that will update the
records in the sqlite database correctly (but running the risk of
later undoing if these changes have not made it to the upstream
source of srs defs too.
Regards
Tim
On 27/09/2006, at 11:22, Laurent C. wrote:
> Hello,
> It seem that the projections parameters for the french lcc
> projection are wrong.
> Today, all the epsg's 275xx have the following parameter :
> +lon_0=-2.33722917
> With the current parameters, when I import some gps points(lat-lon)
> and reproj them to french's Lambert zone II, the points are shifted by
> hundreds of kilometers to the east.
> Maybe the param should be :
> +lon_0=2.33722917
> or maybe :
> +lon_0=0, because +pm=paris
> Well, I don't know exactly.
> Here are my grass PROJ_INFO file (which is working) :
> name: Lambert Conformal Conic
> proj: lcc
> ellps: clark80IGN
> a: 6378249.2000000002
> es: 0.0068034876
> f: 293.4660212940
> lat_0: 46.8000000000
> lat_1: 45.8989188889
> lat_2: 47.6960144444
> lon_0: 2.3372291667
> x_0: 600000.0000000000
> y_0: 2200000.0000000000
> Maybe is it a proj.4 problem. Here is the epsg file from proj 4.4.9 :
> <27572> +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=-2.33722917
> +k_0=0.99987742 +x_0=600000 +y_0=2200000 +a=6378249.2 +b=6356515
> +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs <>
> The epsg file from proj 4.5.0b2 :
> <27572> +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=0 +k_0=0.99987742
> The proj esri file :
> <27572> +proj=lcc +lat_1=46.8 +lat_0=46.8 +lon_0=2.33722917
> +towgs84=-168,-60,320,0,0,0,0 +pm=paris +units=m +no_defs no_defs <>
> I'm not a gis guru, and I don't know exactly what to think. It could
> be great if some French users could give a clue.
> Thanks,
> Laurent
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20060928/53e51e7a/attachment.html
