[Qgis-developer] isfinite <-> std::isfinite
humarco marco.hugentobler at karto.baug.ethz.ch
Fri Sep 29 05:23:05 EDT 2006
Dear developers,
in qgswmsprovider.cpp:1954, there are the following lines of code. I have gcc
version 4.0.3 and this version needs 'std::isfinite' to compile. I wonder
from what version on it needs 'isfinite' without 'std::' . Please post your
compiler versions and if you need 'std::isfinite' or 'isfinite' for it.
cheers,
Marco
#if __GNUC__ >= 4
if(!isfinite(extent.xMin()) || !isfinite((int)extent.yMin()) || !isfinite(extent.xMax()) ||
       !isfinite((int)extent.yMax()))
#else
if(!std::isfinite(extent.xMin()) || !std::isfinite((int)extent.yMin()) || !std::isfinite(extent.xMax()) ||
       !std::isfinite((int)extent.yMax()))
#endif
