[Qgis-developer] make error (wms)
Gavin Macaulay
gavin at macaulay.co.nz
Sat Sep 30 05:55:00 EDT 2006
I'll sort out a check for isfinite/std::isfinite in configure and do this
properly...
Gavin
> Ah, someone else with a compiler requiring std::isfinite.
> What compiler version are you using?
> As a temporary fix, just insert
> #if __GNUC__ >= 5
> instead of
> #if __GNUC__ >= 4
> in qgswmsprovider.cpp:1954. For the longer term, we need to make the
> version
> query more precise.
> Marco
> Am Samstag, 30. September 2006 08:25 schrieb Paolo Cavallini:
>> I'm not able to compile from current svn:
>> qgswmsprovider.Tpo -c qgswmsprovider.cpp -fPIC -DPIC -o
>> .libs/wmsprovider_la-qgswmsprovider.o
>> qgswmsprovider.cpp: In member function 'bool
>> QgsWmsProvider::calculateExtent()':
>> qgswmsprovider.cpp:1955: error: 'isfinite' was not declared in this
>> scope
>> make[5]: *** [wmsprovider_la-qgswmsprovider.lo] Error 1
>> Any explanation?
>> Thanks a lot.
>> pc
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
