[Qgis-developer] qmake not found if qt is in default Troltech's
dir
Gary Sherman
sherman at mrcc.com
Sat Sep 30 13:06:57 EDT 2006
On Sep 29, 2006, at 11:23 PM, Magnus Homann wrote:
>> The Qt utilities need to be in your PATH. You should add $QTDIR/
>> bin to your path prior to compiling. There is no hardcoded path and
>> specifying --with-qtdir doesn't add it to your path during configure.
> Actually, the create_qm_files.sh relies on that the environment
> variable QTDIR is set. It calls "$QTDIR/bin/qmake", instead of just
> "qmake". I had to "export QTDIR=/usr", and then it ran.
> I propose we change this and just use "qmake" instead?
Thats fine -- that approach also requires that the Qt bin directory
is in the PATH.
-gary
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Gary Sherman
Micro Resources: http://mrcc.com
*Geospatial Hosting
*Web Site Hosting
"We work virtually everywhere"
