[Qgis-developer] Question about grass Integration
Stephan Holl stephan.holl at intevation.de
Thu Apr 12 06:53:42 EDT 2007
Hello Nikos,
"Nikos Geronitidis" <geronik444 at gmail.com>, [20070412-13:46:20]:
> Hello
>     I have posted this question in order to contact with Radim Blazek
> who is reported to have done a lot of work with the grass integration
> part, but also to accept
> advices from QGis Developers.
> I am interested in adding new modules for Grass Tools that are part
> of the GrassPlugin.
> I have already red the instructions given at
> http://wiki.qgis.org/qgiswiki/Adding_New_Tools_to_the_GRASS_Toolbox?highlight=%28grass%29
> Is this neccessary when using this method reported on this link, to
> compile the qgis source? Is there an alternative method? (e.g. is it
> possible to add new modules on grass tools
> in an already installed version of qgis?
Yes, it is possible. You just need to copy the relevant XML and
image-files to the appropriate place in your already-installed
QGIS-installation.
QGIS will pick up the modules after a restart of QGIS AFAIK.
Perhaps we should a new paragraph to the wiki which describes how to
integrate new modules in a personal copy of QGIS for local use (and
later integration upstream).
Best
	Stephan
Stephan Holl <stephan.holl at intevation.de>, http://intevation.de/~stephan
Tel: +49 (0)541-33 50 8 32 | Intevation GmbH | AG Osnabrück - HR B 18998
Geschäftsführer:  Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070412/62d2f101/signature.bin
