[Qgis-developer] QgsRasterLayer::drawMultiBandColor
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Fri Aug 17 02:33:33 EDT 2007
On Thursday 16 August 2007 21:35:50 Peter Ersts wrote:
> requires only one value in the channel stack to be nodata to skip the
> current pixel and would be the most robust case
> In your situation where you want 0,0,0 to be 'nodata', but 0,255,255 to
> display that would best be done by setting 0,0,0 as transparent pixel
> rather than saying 0 is the nodatavalue.
I agree that the second version is more robust.
My image example is created by the QGIS georeferencer. Maybe I could change
something there that it uses NaN as nodata value instead of 0. Currently, it
uses the same nodata value as the input image for georeferencing.
Regards,
Marco
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
