[Qgis-developer] x86_64 support
Douglas E. Warner silfreed at silfreed.net
Fri Aug 24 15:10:10 EDT 2007
On Tuesday 31 July 2007, Douglas E. Warner wrote:
> I'm working on a bug for the packages I built for Fedora where the plugins
> aren't found for x86_64.
> (https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=247549)
> I'm thinking this has to do with the fact that qgis is hard-coded to
> install to /usr/lib, where the default path for libraries on x86_64 is
> /usr/lib64. I've created a patch to install the libraries and plugins to
> this directory, but it appears that qgis is still looking in the wrong
> place somehow.
I was curious if anyone had a chance to look into the library installation
problem on 64 bit architectures.  Should I create a bug for this issue?
-Doug
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070824/f736e19c/attachment.bin
