[Qgis-developer] x86_64 support
Douglas E. Warner
silfreed at silfreed.net
Thu Aug 30 16:44:02 EDT 2007
On Thursday 30 August 2007, Jürgen E. Fischer wrote:
> > Where are the plugins installed? Into /usr/lib, or /usr/lib64? Does
> > Debian install 64-bit libraries into /usr/lib64?
> The core+gui shared libraries are installed to /usr/lib and the plugins
> to /usr/lib/qgis
Ah, that's probably why things are working fine. Some distributions like to
install 64-bit libraries to lib64 so that 32-bit and 64-bit libraries can
co-exists side-by-side. Fedora is one of them.
This was fixed back when qgis used autoconf in ticket #27
(https://svn.qgis.org/trac/ticket/27).
If you look at the bug I'm working on for Fedora (bug #27549 -
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=247549) you'll see that
although the patch I attached earlier moves where the libraries are installed
at, it doesn't seem that qgis finds them when starting up.
-Doug
Name: not available
Desc: This is a digitally signed message part.
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070830/612e1030/attachment.bin
