[Qgis-developer] QGIS and platforms
Tim Sutton tim at linfiniti.com
Thu Feb 1 13:03:18 EST 2007
Hi Martin
One other comment I have about cmake (although I think it may have
applied to automake too) is that it doesnt copy over the headers for
qgis needed for writing third party apps etc against the qgis libs. My
install log below illustrates this:
timlinux at timlinux-desktop:~/dev/cpp/qgis/build$ sudo make install
[  0%] Built target svnversion
[  8%] Built target ui
[ 25%] Built target qgis_core
[ 30%] Built target qgis_gui
[ 59%] Built target qgis
[ 62%] Built target translations
[ 63%] Built target qgis_help
[ 63%] Built target ogrprovider
[ 64%] Built target wmsprovider
[ 64%] Built target delimitedtextprovider
[ 65%] Built target postgresprovider
[ 65%] Built target gpxprovider
[ 66%] Built target wfsprovider
[ 66%] Built target qgisgrass
[ 66%] Built target grassprovider
[ 68%] Built target copyrightlabelplugin
[ 69%] Built target delimitedtextplugin
[ 71%] Built target gridmakerplugin
[ 74%] Built target navigationplugin
[ 76%] Built target northarrowplugin
[ 77%] Built target scalebarplugin
[ 78%] Built target pggeoprocessingplugin
[ 82%] Built target spitplugin
[ 85%] Built target gpsimporterplugin
[ 86%] Built target wfsplugin
[ 90%] Built target georefplugin
[ 98%] Built target grassplugin
[100%] Built target msexport
Install the project...
-- Install configuration: ""
-- Installing /usr/local/share/qgis/doc/AUTHORS
-- Installing /usr/local/share/qgis/doc/SPONSORS
-- Installing /usr/local/man/man1/qgis.man
-- Installing /usr/local/lib/libqgis_core.so
-- Installing /usr/local/lib/libqgis_gui.so
-- Installing /usr/local/bin/qgis
-- Installing /usr/local/lib/qgis/libogrprovider.so
-- Installing /usr/local/lib/qgis/libwmsprovider.so
-- Installing /usr/local/lib/qgis/libdelimitedtextprovider.so
-- Installing /usr/local/lib/qgis/libpostgresprovider.so
-- Installing /usr/local/lib/qgis/libgpxprovider.so
-- Installing /usr/local/lib/qgis/libwfsprovider.so
-- Installing /usr/local/lib/libqgisgrass.so
-- Installing /usr/local/lib/qgis/libgrassprovider.so
-- Installing /usr/local/lib/qgis/libcopyrightlabelplugin.so
-- Installing /usr/local/lib/qgis/libdelimitedtextplugin.so
-- Installing /usr/local/lib/qgis/libgridmakerplugin.so
-- Installing /usr/local/lib/qgis/libnavigationplugin.so
-- Installing /usr/local/lib/qgis/libnortharrowplugin.so
-- Installing /usr/local/lib/qgis/libscalebarplugin.so
-- Installing /usr/local/lib/qgis/libpggeoprocessingplugin.so
-- Installing /usr/local/lib/qgis/libspitplugin.so
-- Installing /usr/local/lib/qgis/libgpsimporterplugin.so
-- Installing /usr/local/lib/qgis/libwfsplugin.so
-- Installing /usr/local/lib/qgis/libgeorefplugin.so
-- Installing /usr/local/lib/qgis/libgrassplugin.so
-- Installing /usr/local/share/qgis/grass/locations.gml
-- Installing /usr/local/share/qgis/grass/world.png
-- Installing /usr/local/share/qgis/grass/config/default.qgc
-- Installing /usr/local/share/qgis/grass/modules/v.in.region.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.mkgrid.region.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.surf.idw.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.in.gdal.qgm
-- Installing /usr/local/share/qgis/grass/modules/g.gisenv.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.random.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.extract.where.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.shaded.relief.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.colors.qgm
-- Installing /usr/local/share/qgis/grass/modules/shell.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.hull.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.to.vect.point.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.neighbors.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.clump.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.net.alloc.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.null.null.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.neighbors.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.category.sum.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.and.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.null.val.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.xor.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.mapcalc.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.or.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.buffer.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.reclass.attr.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.category.del.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.type.cp.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.net.salesman.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.voronoi.area.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.to.rast.attr.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.category.add.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.to.vect.line.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.out.gdal.gtiff.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.buffer.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.slope.aspect.aspect.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.kernel.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.select.overlap.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.delaunay.line.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.out.ogr.shape.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.in.ogr.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.thin.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.net.nodes.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.to.db.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.slope.aspect.slope.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.type.bl.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.not.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.extract.list.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.surf.rst.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.net.steiner.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.out.ogr.gml.qgm
-- Installing /usr/local/share/qgis/grass/modules/r.to.vect.area.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.to.rast.constant.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.delaunay.area.qgm
-- Installing /usr/local/share/qgis/grass/modules/nviz.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.type.lb.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.net.iso.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.voronoi.line.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.type.pc.qgm
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.not.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.iso.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.not.3.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.and.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.voronoi.line.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.and.3.svg
-- Installing /usr/local/share/qgis/grass/modules/v.extract.list.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.xor.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.steiner.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.mkgrid.region.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.or.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.extract.where.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.to.rast.constant.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.salesman.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.nodes.1.svg
-- Installing /usr/local/share/qgis/grass/modules/r.to.vect.line.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.alloc.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.select.overlap.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.in.region.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.select.overlap.3.svg
-- Installing /usr/local/share/qgis/grass/modules/v.delaunay.line.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.out.ogr.shape.2.svg
-- Installing /usr/local/share/qgis/grass/modules/r.buffer.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.buffer.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.out.ogr.gml.2.svg
-- Installing /usr/local/share/qgis/grass/modules/r.to.vect.area.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.iso.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.not.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.and.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.extract.list.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.xor.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.xor.3.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.steiner.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.or.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.overlay.or.3.svg
-- Installing /usr/local/share/qgis/grass/modules/v.to.rast.constant.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.extract.where.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.salesman.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.nodes.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.voronoi.area.2.svg
-- Installing /usr/local/share/qgis/grass/modules/r.to.vect.line.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.net.alloc.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.select.overlap.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.in.ogr.1.svg
-- Installing /usr/local/share/qgis/grass/modules/r.buffer.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.buffer.2.svg
-- Installing /usr/local/share/qgis/grass/modules/r.to.vect.area.2.svg
-- Installing /usr/local/share/qgis/grass/modules/r.to.vect.point.1.svg
-- Installing /usr/local/share/qgis/grass/modules/v.hull.2.svg
-- Installing /usr/local/share/qgis/grass/modules/v.delaunay.area.2.svg
-- Installing /usr/local/share/qgis/grass/modules/r.slope.aspect.aspect.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.out.ogr.shape.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.thin.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.reclass.attr.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.reclass.attr.3.png
-- Installing /usr/local/share/qgis/grass/modules/r.in.gdal.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.out.ogr.gml.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.to.rast.attr.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.to.db.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.out.gdal.gtiff.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.neighbors.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.clump.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.type.lb.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.neighbors.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.category.sum.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.surf.rst.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.surf.idw.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.category.del.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.type.cp.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.shaded.relief.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.colors.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.voronoi.area.1.png
-- Installing /usr/local/share/qgis/grass/modules/shell.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.category.add.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.slope.aspect.slope.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.type.bl.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.null.null.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.kernel.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.type.pc.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.null.val.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.in.ogr.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.thin.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.reclass.attr.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.in.gdal.1.png
-- Installing /usr/local/share/qgis/grass/modules/g.gisenv.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.random.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.to.rast.attr.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.hull.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.to.rast.attr.3.png
-- Installing /usr/local/share/qgis/grass/modules/v.to.db.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.out.gdal.gtiff.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.to.vect.point.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.delaunay.area.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.neighbors.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.clump.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.type.lb.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.neighbors.3.png
-- Installing /usr/local/share/qgis/grass/modules/v.neighbors.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.category.sum.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.voronoi.line.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.category.sum.3.png
-- Installing /usr/local/share/qgis/grass/modules/v.surf.rst.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.mapcalc.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.surf.idw.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.category.del.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.type.cp.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.colors.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.shaded.relief.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.shaded.relief.3.png
-- Installing /usr/local/share/qgis/grass/modules/v.category.add.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.type.bl.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.slope.aspect.aspect.2.png
-- Installing /usr/local/share/qgis/grass/modules/r.slope.aspect.slope.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.kernel.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.null.null.2.png
-- Installing /usr/local/share/qgis/grass/modules/v.type.pc.1.png
-- Installing /usr/local/share/qgis/grass/modules/nviz.1.png
-- Installing /usr/local/share/qgis/grass/modules/v.delaunay.line.1.png
-- Installing /usr/local/share/qgis/grass/modules/r.null.val.2.png
-- Installing /usr/local/share/qgis/themes/default/grass/mapcalc_add_connection.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_module_error.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_tools.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_new_line.png
-- Installing /usr/local/share/qgis/themes/default/grass/mapcalc_select.png
-- Installing /usr/local/share/qgis/themes/default/grass/mapcalc_save_as.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_move_vertex.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_rename_map.png
-- Installing /usr/local/share/qgis/themes/default/grass/mapcalc_add_map.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_copy_map.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_add_raster.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_delete_line.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_module_warning.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_add_vector.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_close_edit.png
-- Installing /usr/local/share/qgis/themes/default/grass/mapcalc_save.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_new_boundary.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_set_region.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_refresh.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_delete_map.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_browser_raster_layer.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_delete_vertex.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_split_line.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_browser_vector_layer.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_new_point.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_move_line.png
-- Installing /usr/local/share/qgis/themes/default/grass/mapcalc_add_function.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_new_centroid.png
-- Installing /usr/local/share/qgis/themes/default/grass/mapcalc_add_constant.png
-- Installing /usr/local/share/qgis/themes/default/grass/mapcalc_open.png
-- Installing /usr/local/share/qgis/themes/default/grass/mapcalc_delete.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_add_map.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_add_vertex.png
-- Installing /usr/local/share/qgis/themes/default/grass/grass_edit_attributes.png
-- Installing /usr/local/bin/qgis_help
-- Installing /usr/local/share/qgis/doc/favicon.ico
-- Installing /usr/local/share/qgis/doc/index.html
-- Installing /usr/local/share/qgis/doc/install.pdf
-- Installing /usr/local/share/qgis/doc/qgisdoc.css
-- Installing /usr/local/share/qgis/doc/userguide.pdf
-- Installing /usr/local/share/qgis/doc/images/qgis_new_80pct.png
-- Installing /usr/local/share/qgis/images/north_arrows/default.png
-- Installing /usr/local/share/qgis/images/splash/splash_mask.png
-- Installing /usr/local/share/qgis/images/splash/splash.png
-- Installing /usr/local/share/qgis/images/icons/qgis-icon-16x16.png
-- Installing /usr/local/share/qgis/images/icons/qgis-mime-icon.png
-- Installing /usr/local/share/qgis/images/icons/qgis-icon.png
-- Installing /usr/local/share/qgis/images/icons/qgis-icon-60x60.png
-- Installing /usr/local/share/qgis/images/developers/Christoph_Spoerri.jpg
-- Installing /usr/local/share/qgis/images/developers/Gary_E.Sherman.jpg
-- Installing /usr/local/share/qgis/images/developers/Denis_Antipov.jpg
-- Installing /usr/local/share/qgis/images/developers/Tim_Sutton.jpg
-- Installing /usr/local/share/qgis/images/developers/Godofredo_Contreras.jpg
-- Installing /usr/local/share/qgis/images/developers/Carl_Anderson.jpg
-- Installing /usr/local/share/qgis/images/developers/Martin_Dobias.jpg
-- Installing /usr/local/share/qgis/images/developers/Mark_Coletti.jpg
-- Installing /usr/local/share/qgis/images/developers/Gavin_Macaulay.jpg
-- Installing /usr/local/share/qgis/images/developers/Masaru_Hoshi.jpg
-- Installing /usr/local/share/qgis/images/developers/Jens_Oberender.jpg
-- Installing /usr/local/share/qgis/images/developers/Radim_Blazek.jpg
-- Installing /usr/local/share/qgis/images/developers/Peter_Brewer.jpg
-- Installing /usr/local/share/qgis/images/developers/Tom_Elwertowski.jpg
-- Installing /usr/local/share/qgis/images/developers/Steve_Halasz.jpg
-- Installing /usr/local/share/qgis/images/developers/Lars_Luthman.jpg
-- Installing /usr/local/share/qgis/images/developers/Marco_Hugentobler.jpg
-- Installing /usr/local/share/qgis/themes/default/mActionShowPluginManager.png
-- Installing /usr/local/share/qgis/themes/default/mActionHideAllLayers.png
-- Installing /usr/local/share/qgis/themes/default/mActionEditPaste.png
-- Installing /usr/local/share/qgis/themes/default/mActionCopySelected.png
-- Installing /usr/local/share/qgis/themes/default/mActionShowBookmarks.png
-- Installing /usr/local/share/qgis/themes/default/mActionInOverview.png
-- Installing /usr/local/share/qgis/themes/default/mActionRemove.png
-- Installing /usr/local/share/qgis/themes/default/mActionStartEditing.png
-- Installing /usr/local/share/qgis/themes/default/mActionFileOpen.png
-- Installing /usr/local/share/qgis/themes/default/mIconGeometryLayer.png
-- Installing /usr/local/share/qgis/themes/default/mIconPointLayer.png
-- Installing /usr/local/share/qgis/themes/default/mActionRemoveAllFromOverview.png
-- Installing /usr/local/share/qgis/themes/default/mIconProjectionEnabled.png
-- Installing /usr/local/share/qgis/themes/default/mActionAddLegend.png
-- Installing /usr/local/share/qgis/themes/default/mActionCheckQgisVersion.png
-- Installing /usr/local/share/qgis/themes/default/mActionQgisHomePage.png
-- Installing /usr/local/share/qgis/themes/default/mActionCaptureLine.png
-- Installing /usr/local/share/qgis/themes/default/mActionZoomIn.png
-- Installing /usr/local/share/qgis/themes/default/mActionCapturePoint.png
-- Installing /usr/local/share/qgis/themes/default/mActionPan.png
-- Installing /usr/local/share/qgis/themes/default/mActionNewBookmark.png
-- Installing /usr/local/share/qgis/themes/default/mActionProjectProperties.png
-- Installing /usr/local/share/qgis/themes/default/mActionHelpAbout.png
-- Installing /usr/local/share/qgis/themes/default/mActionZoomToLayer.png
-- Installing /usr/local/share/qgis/themes/default/mActionNewFolder.png
-- Installing /usr/local/share/qgis/themes/default/mActionFileNew.png
-- Installing /usr/local/share/qgis/themes/default/mActionMeasureArea.png
-- Installing /usr/local/share/qgis/themes/default/mActionExpandTree.png
-- Installing /usr/local/share/qgis/themes/default/mActionZoomFullExtent.png
-- Installing /usr/local/share/qgis/themes/default/mActionDeleteVertex.png
-- Installing /usr/local/share/qgis/themes/default/mActionNewAttribute.png
-- Installing /usr/local/share/qgis/themes/default/mActionMeasure.png
-- Installing /usr/local/share/qgis/themes/default/mActionEditCut.png
-- Installing /usr/local/share/qgis/themes/default/mIconProperties.png
-- Installing /usr/local/share/qgis/themes/default/mActionFileSmall.png
-- Installing /usr/local/share/qgis/themes/default/mActionFolder.png
-- Installing /usr/local/share/qgis/themes/default/mActionScaleBar.png
-- Installing /usr/local/share/qgis/themes/default/mActionAddAllToOverview.png
-- Installing /usr/local/share/qgis/themes/default/mActionFileSaveAs.png
-- Installing /usr/local/share/qgis/themes/default/mIconNoPyramid.png
-- Installing /usr/local/share/qgis/themes/default/mAction.png
-- Installing /usr/local/share/qgis/themes/default/mActionEditCopy.png
-- Installing /usr/local/share/qgis/themes/default/mActionDeleteAttribute.png
-- Installing /usr/local/share/qgis/themes/default/mActionCollapseTree.png
-- Installing /usr/local/share/qgis/themes/default/mActionAddVertex.png
-- Installing /usr/local/share/qgis/themes/default/mActionZoomToSelected.png
-- Installing /usr/local/share/qgis/themes/default/mActionShowAllLayers.png
-- Installing /usr/local/share/qgis/themes/default/mActionStopEditing.png
-- Installing /usr/local/share/qgis/themes/default/mActionLabel.png
-- Installing /usr/local/share/qgis/themes/default/mActionUnselectAttributes.png
-- Installing /usr/local/share/qgis/themes/default/mActionMoveVertex.png
-- Installing /usr/local/share/qgis/themes/default/mActionHelpContents.png
-- Installing /usr/local/share/qgis/themes/default/mActionCustomProjection.png
-- Installing /usr/local/share/qgis/themes/default/mActionNewVectorLayer.png
-- Installing /usr/local/share/qgis/themes/default/mActionFileExit.png
-- Installing /usr/local/share/qgis/themes/default/mIconUnknownLayerType.png
-- Installing /usr/local/share/qgis/themes/default/mActionDeleteSelected.png
-- Installing /usr/local/share/qgis/themes/default/mActionAddWmsLayer.png
-- Installing /usr/local/share/qgis/themes/default/mActionZoomOut.png
-- Installing /usr/local/share/qgis/themes/default/mActionSelect.png
-- Installing /usr/local/share/qgis/themes/default/mIconPyramid.png
-- Installing /usr/local/share/qgis/themes/default/mActionSaveMapAsImage.png
-- Installing /usr/local/share/qgis/themes/default/mIconWaitingForLayerType.png
-- Installing /usr/local/share/qgis/themes/default/mIconEditable.png
-- Installing /usr/local/share/qgis/themes/default/mActionAddLayer.png
-- Installing /usr/local/share/qgis/themes/default/mIconLayer.png
-- Installing /usr/local/share/qgis/themes/default/mActionRemoveLayer.png
-- Installing /usr/local/share/qgis/themes/default/mActionOptions.png
-- Installing /usr/local/share/qgis/themes/default/mActionFilePrint.png
-- Installing /usr/local/share/qgis/themes/default/mActionContextHelp.png
-- Installing /usr/local/share/qgis/themes/default/mActionDraw.png
-- Installing /usr/local/share/qgis/themes/default/mActionFileSave.png
-- Installing /usr/local/share/qgis/themes/default/mIconLineLayer.png
-- Installing /usr/local/share/qgis/themes/default/mIconPolygonLayer.png
-- Installing /usr/local/share/qgis/themes/default/mIconSymbology.png
-- Installing /usr/local/share/qgis/themes/default/mActionSaveAsSVG.png
-- Installing /usr/local/share/qgis/themes/default/mActionPropertyItem.png
-- Installing /usr/local/share/qgis/themes/default/mActionAddRasterLayer.png
-- Installing /usr/local/share/qgis/themes/default/mActionAddNonDbLayer.png
-- Installing /usr/local/share/qgis/themes/default/mActionExportMapServer.png
-- Installing /usr/local/share/qgis/themes/default/mActionZoomLast.png
-- Installing /usr/local/share/qgis/themes/default/mIconProjectionProblem.png
-- Installing /usr/local/share/qgis/themes/default/mMapserverExport.png
-- Installing /usr/local/share/qgis/themes/default/mActionOpenTable.png
-- Installing /usr/local/share/qgis/themes/default/mActionIdentify.png
-- Installing /usr/local/share/qgis/themes/default/mActionCapturePolygon.png
-- Installing /usr/local/share/qgis/themes/default/mActionInvertSelection.png
-- Installing /usr/local/share/qgis/themes/default/mActionSelectedToTop.png
-- Installing /usr/local/share/qgis/themes/default/mIconProjectionDisabled.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionShowPluginManager.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionHideAllLayers.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionFileSaveAs.png
-- Installing /usr/local/share/qgis/themes/nkids/contexthelp.png
-- Installing /usr/local/share/qgis/themes/nkids/gis_plain_cursor.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionShowAllLayers.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionShowBookmarks.png
-- Installing /usr/local/share/qgis/themes/nkids/show_all_layers1.png
-- Installing /usr/local/share/qgis/themes/nkids/qgis32x32.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionZoomToSelected.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionInOverview.png
-- Installing /usr/local/share/qgis/themes/nkids/delete_selected.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionHelpContents.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionFileOpen.png
-- Installing /usr/local/share/qgis/themes/nkids/action.png
-- Installing /usr/local/share/qgis/themes/nkids/over.png
-- Installing /usr/local/share/qgis/themes/nkids/mIconProjectionEnabled.png
-- Installing /usr/local/share/qgis/themes/nkids/remove_all_to_overview.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionCustomProjection.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionFileExit.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionNewVectorLayer.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionQgisHomePage.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionCaptureLine.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionZoomIn.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionAddWmsLayer.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionZoomOut.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionCapturePoint.png
-- Installing /usr/local/share/qgis/themes/nkids/over-.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionPan.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionNewBookmark.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionSelect.png
-- Installing /usr/local/share/qgis/themes/nkids/over1.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionHelpAbout.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionProjectProperties.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionSaveMapAsImage.png
-- Installing /usr/local/share/qgis/themes/nkids/layers.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionZoomToLayer.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionAddLayer.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionFileNew.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionRemoveLayer.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionOptions.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionFilePrint.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionDraw.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionFileSave.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionZoomFullExtent.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionAddNonDbLayer.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionMeasure.png
-- Installing /usr/local/share/qgis/themes/nkids/show_layerReal.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionRemoveAllFromOverview.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionExportMapServer.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionAddRasterLayer.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionZoomLast.png
-- Installing /usr/local/share/qgis/themes/nkids/mIconProjectionProblem.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionOpenTable.png
-- Installing /usr/local/share/qgis/themes/nkids/inline_table.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionIdentify.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionCapturePolygon.png
-- Installing /usr/local/share/qgis/themes/nkids/mActionAddAllToOverview.png
-- Installing /usr/local/share/qgis/themes/nkids/mIconProjectionDisabled.png
-- Installing /usr/local/share/qgis/svg/biology/Deciduous.svg
-- Installing /usr/local/share/qgis/svg/biology/Coniferous.svg
-- Installing /usr/local/share/qgis/svg/biology/Flower.svg
-- Installing /usr/local/share/qgis/svg/geometric/Triangle1.svg
-- Installing /usr/local/share/qgis/svg/geometric/Square1.svg
-- Installing /usr/local/share/qgis/svg/geometric/Square2.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/walker.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/boat.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/city_building.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/golf.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/food.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/couple.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/point.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/fish.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/cross.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/skull.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/plane.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/tree.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/city_small.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/car.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/question.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/city_medium.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/phone.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/gas.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/anchor.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/waypoint.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/bank.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/skier.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/dollar.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/city_large.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/house.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/swimmer.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/h.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/table.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/camera.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/parking.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/conveneince.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/shipwreck.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/teepee.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/flag.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/parachute.svg
-- Installing /usr/local/share/qgis/svg/gpsicons/deer.svg
-- Installing /usr/local/share/qgis/svg/icon/golfcourse.svg
-- Installing /usr/local/share/qgis/svg/north_arrows/NorthArrow1.svg
-- Installing /usr/local/share/qgis/svg/north_arrows/default.svg
-- Installing /usr/local/share/qgis/svg/north_arrows/NorthArrow2.svg
-- Installing /usr/local/share/qgis/svg/north_arrows/NorthArrow3.svg
-- Installing /usr/local/share/qgis/svg/north_arrows/NorthArrow4.svg
-- Installing /usr/local/share/qgis/svg/north_arrows/NorthArrow5.svg
-- Installing /usr/local/share/qgis/svg/north_arrows/NorthArrow6.svg
-- Installing /usr/local/share/qgis/svg/sport/golf_flag_in_hole_on_gr_01.svg
-- Installing /usr/local/share/qgis/svg/sport/backpacker_ganson.svg
-- Installing /usr/local/share/qgis/svg/symbol/Cross1.svg
-- Installing /usr/local/share/qgis/svg/symbol/Star1.svg
-- Installing /usr/local/share/qgis/svg/symbol/Cross2.svg
-- Installing /usr/local/share/qgis/svg/symbol/Star2.svg
-- Installing /usr/local/share/qgis/svg/symbol/Star3.svg
-- Installing /usr/local/share/qgis/svg/symbol/Cross4.svg
-- Installing /usr/local/share/qgis/svg/symbol/Cross5.svg
-- Installing /usr/local/share/qgis/svg/symbol/Cross6.svg
-- Installing /usr/local/share/qgis/resources/srs.db
-- Installing /usr/local/share/qgis/resources/qgis.db
-- Installing /usr/local/share/qgis/resources/qgis_help.db
-- Installing /usr/local/share/qgis/resources/context_help/863656587_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/687883780_en_US
-- Installing /usr/local/share/qgis/resources/context_help/929865718_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/308026563_en_US
-- Installing /usr/local/share/qgis/resources/context_help/94000531_en_US
-- Installing /usr/local/share/qgis/resources/context_help/710979116_en_US
-- Installing /usr/local/share/qgis/resources/context_help/151694916_en_US
-- Installing /usr/local/share/qgis/resources/context_help/165149618_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/32338213_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/361087368_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/831088384_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/939347163_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/1033030847_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/151694916_sv_SE
-- Installing /usr/local/share/qgis/resources/context_help/985715179_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/995980174_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/863656587_en_US
-- Installing /usr/local/share/qgis/resources/context_help/689216579_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/929865718_en_US
-- Installing /usr/local/share/qgis/resources/context_help/687883780_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/308026563_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/94000531_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/165149618_en_US
-- Installing /usr/local/share/qgis/resources/context_help/32338213_en_US
-- Installing /usr/local/share/qgis/resources/context_help/710979116_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/361087368_en_US
-- Installing /usr/local/share/qgis/resources/context_help/831088384_en_US
-- Installing /usr/local/share/qgis/resources/context_help/151694916_sk_SK
-- Installing /usr/local/share/qgis/resources/context_help/939347163_en_US
-- Installing /usr/local/share/qgis/resources/context_help/1033030847_en_US
-- Installing /usr/local/share/qgis/resources/context_help/32338213_sv_SE
-- Installing /usr/local/share/qgis/resources/context_help/361087368_sv_SE
-- Installing /usr/local/share/qgis/resources/context_help/985715179_en_US
-- Installing /usr/local/share/qgis/resources/context_help/995980174_en_US
-- Installing /usr/local/share/qgis/resources/context_help/689216579_en_US
-- Installing /usr/local/share/qgis/i18n/qgis_cs_CZ.qm
-- Installing /usr/local/share/qgis/i18n/qgis_fr.qm
-- Installing /usr/local/share/qgis/i18n/qgis_es.qm
-- Installing /usr/local/share/qgis/i18n/qt_zh_CN.qm
-- Installing /usr/local/share/qgis/i18n/qgis_nl.qm
-- Installing /usr/local/share/qgis/i18n/qgis_it.qm
-- Installing /usr/local/share/qgis/i18n/qgis_sk.qm
-- Installing /usr/local/share/qgis/i18n/qgis_vi.qm
-- Installing /usr/local/share/qgis/i18n/qgis_ro.qm
-- Installing /usr/local/share/qgis/i18n/qgis_lv.qm
-- Installing /usr/local/share/qgis/i18n/qgis_ru.qm
-- Installing /usr/local/share/qgis/i18n/qgis_de.qm
-- Installing /usr/local/share/qgis/i18n/qgis_sv.qm
-- Installing /usr/local/share/qgis/i18n/qgis_ja.qm
-- Installing /usr/local/share/qgis/i18n/qgis_id.qm
-- Installing /usr/local/share/qgis/i18n/qgis_zh_CN.qm
-- Installing /usr/local/share/qgis/i18n/qt_ru.qm
-- Installing /usr/local/share/qgis/i18n/qgis_pt_BR.qm
-- Installing /usr/local/share/qgis/i18n/qgis_pl_PL.qm
-- Installing /usr/local/share/qgis/i18n/qt_de.qm
-- Installing /usr/local/share/qgis/i18n/qt_sv.qm
-- Installing /usr/local/share/qgis/i18n/qt_es.qm
-- Installing /usr/local/share/qgis/i18n/qt_fr.qm
-- Installing /usr/local/share/qgis/i18n/qt_sk.qm
-- Installing /usr/local/bin/msexport
-- Installing /usr/local/share/qgis/python/ms_export.py
-- Installing /usr/local/share/qgis/python/test_export.py
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
