[Qgis-developer] Mac OSX - Clean machine setup issues
Tim Sutton
tim at linfiniti.com
Sun Feb 4 05:59:54 EST 2007
Hi
Thanks for the replies Tom / William / Magnus
I bit the bullet and built expat / gsl / sip / pyqt from source. For
some reason SIP does net get found though:
tims-computer:~/dev/cpp/qgis/build tim$ cmake -D
CMAKE_INSTALL_PREFIX=/Users/tim/apps/ -D
GDAL_CONFIG=/Library/Frameworks/GDAL.framework/unix/bin/gdal-config -D
GRASS_PREFIX=/Applications/GRASS.app/Contents/Resources -D
GSL_CONFIG=/usr/local/bin/gsl-config -D WITH_BINDINGS=ON -D
WITH_GRASS=ON ..
-- Found Proj: /Library/Frameworks/proj.framework
-- Found Sqlite3: /Library/Frameworks/sqlite3.framework
-- Found GEOS: /Library/Frameworks/geos.framework
-- Found GDAL: /Library/Frameworks/GDAL.framework/unix/lib/libgdal.so
-- Could not find PostgreSQL
-- Found Expat: /usr/local/lib/libexpat.dylib
-- Using GSL from /usr/local
-- Found GRASS: /Applications/GRASS.app/Contents/Resources (6.3.0-CVS-07012401)
-- Python libraries found
-- SIP not found!
-- Python bindings disabled due dependency problems!
-- Found Qt-Version 4.2.2
-- Configuring done
-- Generating done
-- Build files have been written to: /Users/tim/dev/cpp/qgis/build
Grass does seem to be found ok from Williams GRASS.app using the
configuration option shown above. Tom any idea what to do to get SIP
detected properly?
Regards
Tim
On 2/4/07, Tom Elwertowski <telwertowski at comcast.net> wrote:
> William Kyngesburye wrote:
> > A question on cmake - how well does it handle universal flags?
> I haven't tried this but adding additional architectures by editing
> CMakeCache.txt is supposed to work.
> CMAKE_OSX_ARCHITECTURES:STRING=ppc;i386
> My file currently contains:
> /Build architectures for OSX
> //isysroot used for universal binary support
> CMAKE_OSX_SYSROOT:STRING=/Developer/SDKs/MacOSX10.4u.sdk
> Tom
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
