[Qgis-developer] SVN TRUNK: Problems compiling third party app
using qgis libs
Tim Sutton
tim at linfiniti.com
Wed Feb 7 11:30:25 EST 2007
Hi
I'm trying to get my openModeller stuff (which uses qgis libs for map
display) to compile against trunk built with cmake. I use
QgsApplication as the base class for openModeller Desktop but there is
a hiccup when compiling (see below). Its using the headers put into
/usr/local/include/qgis after doing a make install in qgis. Does
anyone have an idea whats potting here?
Thanks
Tim
make[2]: Entrando no diretório
`/home/timlinux/dev/cpp/openModellerDesktop/src/gui'
g++ -c -pipe -O2 -w -D_REENTRANT -DQGISPLUGINDIR=/usr/local/lib/qgis
-DWITH_QGIS -DWITH_LOCAL_PLUGIN -DWITH_WEBSERVICES_PLUGIN
-DOMG_NO_EXPERIMENTAL -DQT_NO_DEBUG -DQT_QT3SUPPORT_LIB -DQT3_SUPPORT
-DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_SHARED
-I/usr/local/Trolltech/Qt-4.2.0/mkspecs/linux-g++ -I.
-I/usr/local/Trolltech/Qt-4.2.0/include/QtCore
-I/usr/local/Trolltech/Qt-4.2.0/include/QtNetwork
-I/usr/local/Trolltech/Qt-4.2.0/include/QtGui
-I/usr/local/Trolltech/Qt-4.2.0/include/QtXml
-I/usr/local/Trolltech/Qt-4.2.0/include/Qt3Support
-I/usr/local/Trolltech/Qt-4.2.0/include -I/usr/local/include/qgis
-I../lib -I../lib/modellerplugins -I../widgets -I../../obj/moc
-I../../obj/ui -o ../../obj/o/linux/main.o main.cpp
/usr/local/include/qgis/qgspoint.h:26: error: invalid function declaration
/usr/local/include/qgis/qgspoint.h:124: error: expected ',' or '...'
before '&' token
/usr/local/include/qgis/qgspoint.h:124: error: ISO C++ forbids
declaration of 'QgsPoint' with no type
/usr/local/include/qgis/qgspoint.h:124: error: 'bool operator==(int)'
must have an argument of class or enumerated type
must take exactly two arguments
/usr/local/include/qgis/qgspoint.h: In function 'bool operator==(int)':
/usr/local/include/qgis/qgspoint.h:126: error: 'p1' was not declared
in this scope
/usr/local/include/qgis/qgspoint.h:126: error: 'p2' was not declared
in this scope
/usr/local/include/qgis/qgspoint.h: At global scope:
/usr/local/include/qgis/qgspoint.h:132: error: expected ',' or '...'
before '&' token
/usr/local/include/qgis/qgspoint.h:132: error: ISO C++ forbids
/usr/local/include/qgis/qgspoint.h: In function 'std::ostream&
operator<<(std::ostream&, int)':
/usr/local/include/qgis/qgspoint.h:135: error: 'p' was not declared in
this scope
/usr/local/include/qgis/qgsrect.h: At global scope:
/usr/local/include/qgis/qgsrect.h:35: error: invalid function declaration
/usr/local/include/qgis/qgsrect.h:132: error: expected initializer
before '::' token
/usr/local/include/qgis/qgsrect.h:136: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h: In function 'void setXmin(double)':
/usr/local/include/qgis/qgsrect.h:138: error: 'xmin' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:141: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h: In function 'void setXmax(double)':
/usr/local/include/qgis/qgsrect.h:143: error: 'xmax' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:146: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h: In function 'void setYmin(double)':
/usr/local/include/qgis/qgsrect.h:148: error: 'ymin' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:151: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h: In function 'void setYmax(double)':
/usr/local/include/qgis/qgsrect.h:153: error: 'ymax' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:156: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h:156: error: non-member function
'double xMax()' cannot have cv-qualifier
/usr/local/include/qgis/qgsrect.h: In function 'double xMax()':
/usr/local/include/qgis/qgsrect.h:158: error: 'xmax' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:161: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h:161: error: non-member function
'double xMin()' cannot have cv-qualifier
/usr/local/include/qgis/qgsrect.h: In function 'double xMin()':
/usr/local/include/qgis/qgsrect.h:163: error: 'xmin' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:166: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h:166: error: non-member function
'double yMax()' cannot have cv-qualifier
/usr/local/include/qgis/qgsrect.h: In function 'double yMax()':
/usr/local/include/qgis/qgsrect.h:168: error: 'ymax' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:171: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h:171: error: non-member function
'double yMin()' cannot have cv-qualifier
/usr/local/include/qgis/qgsrect.h: In function 'double yMin()':
/usr/local/include/qgis/qgsrect.h:173: error: 'ymin' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:176: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h:176: error: non-member function
'double width()' cannot have cv-qualifier
/usr/local/include/qgis/qgsrect.h: In function 'double width()':
/usr/local/include/qgis/qgsrect.h:178: error: 'xmax' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:178: error: 'xmin' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:181: error: 'QgsRect' has not been declared
/usr/local/include/qgis/qgsrect.h:181: error: non-member function
'double height()' cannot have cv-qualifier
/usr/local/include/qgis/qgsrect.h: In function 'double height()':
/usr/local/include/qgis/qgsrect.h:183: error: 'ymax' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:183: error: 'ymin' was not declared
in this scope
/usr/local/include/qgis/qgsrect.h:186: error: 'QgsPoint' does not name a type
/usr/local/include/qgis/qgsrect.h:190: error: expected ',' or '...'
before '&' token
/usr/local/include/qgis/qgsrect.h:190: error: ISO C++ forbids
declaration of 'QgsRect' with no type
/usr/local/include/qgis/qgsrect.h: In function 'std::ostream&
/usr/local/include/qgis/qgsrect.h:190: error: redefinition of
'std::ostream& operator<<(std::ostream&, int)'
/usr/local/include/qgis/qgspoint.h:132: error: 'std::ostream&
operator<<(std::ostream&, int)' previously defined here
/usr/local/include/qgis/qgsrect.h:192: error: 'r' was not declared in this scope
/usr/local/include/qgis/qgis.h: At global scope:
/usr/local/include/qgis/qgis.h:35: error: invalid function declaration
/usr/local/include/qgis/qgsmapcanvas.h:62: error: invalid function declaration
/usr/local/include/qgis/qgsmapcanvas.h:93: error: invalid function declaration
/usr/local/include/qgis/qgsmaptool.h:32: error: invalid function declaration
/usr/local/include/qgis/qgsapplication.h:21: error: invalid function declaration
main.cpp: In function 'int main(int, char**)':
main.cpp:54: error: 'QgsApplication' was not declared in this scope
main.cpp:54: error: expected `;' before 'myApp'
main.cpp:112: error: 'myApp' was not declared in this scope
main.cpp:121: error: 'myApp' was not declared in this scope
main.cpp:135: error: 'myApp' was not declared in this scope
make[2]: ** [../../obj/o/linux/main.o] Erro 1
make[2]: Saindo do diretório
make[1]: ** [sub-gui-make_default] Erro 2
make[1]: Saindo do diretório `/home/timlinux/dev/cpp/openModellerDesktop/src'
make: ** [sub-src-make_default] Erro 2
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
