[Qgis-developer] Re: qgssvnversion.h and compile problem
Gavin Macaulay
gavin at macaulay.co.nz
Thu Feb 8 03:51:08 EST 2007
I don't think that Tim's suggestion for replacing qgssvnversion.h would
work. Having some special text in a file that svn automatically replaces
with the version number (aka $Id:$ with cvs) will result in something that
only gets updated when that file is changed. For example, if a commit is
made to a separate file, svn won't update the file that contains the
special text.
As far as I can see, running the svnversion command and placing that
output somewhere where qgis can see it (at compile time or run time) is
the only way to get an up-to-date version number.
Gavin
> Hi,
> I think this is due some of the recent commits which were made to fix
> compilation with 'MSYS Makefiles' generator and probably has broken
> 'MinGW Makefiles'.
> I think Tim has a definite and much better solution for showing SVN
> revision, with that fix we should be able to forget all these
> problems.
> If you're asking for an immediate solution, just edit qgssvnversion.h
> and delete the backslashes.
> Martin
> On 2/8/07, Byambaa Mendbayar <mendbayar_b at mongol.net> wrote:
>> Dear developers,
>> I have a problem when I compile svn head.
>> D:\devel\workplace\unstable\qgis_head\build>cmake -G "MinGW Makefiles"
>> -DGRASS_P
>> REFIX=D:\devel\bin\msys\local\grass-6.3.cvs
>> -DCMAKE_INSTALL_PREFIX=D:\devel\work
>> place\unstable\qgis_head\apps D:\devel\workplace\unstable\qgis_head
>> -- Found Proj: D:/devel/bin/msys/local/lib/libproj.a
>> -- Found Sqlite3: D:/devel/bin/msys/local/lib/libsqlite3.a
>> -- Found GEOS: D:/devel/bin/msys/local/lib/libgeos.dll.a
>> -- Found GDAL: D:/devel/bin/msys/local/lib/libgdal.dll.a
>> -- Found PostgreSQL: D:/devel/bin/msys/local/lib/libpq.dll
>> -- Found Expat: D:/devel/bin/msys/local/lib/libexpat.dll.a
>> -- Using GSL from D:/devel/bin/msys/local
>> -- Found GRASS: D:/devel/bin/msys/local/grass-6.3.cvs (6.3.cvs)
>> -- Found Qt-Version 4.2.2
>> -- Configuring done
>> -- Generating done
>> -- Build files have been written to:
>> D:/devel/workplace/unstable/qgis_head/build
>> D:\devel\workplace\unstable\qgis_head\build>make
>> [ 0%] Built target svnversion
>> [ 8%] Built target ui
>> [ 9%] Building CXX object src/core/CMakeFiles/qgis_core.dir/qgis.obj
>> In file included from
>> D:\devel\workplace\unstable\qgis_head\src\core\qgis.cpp:4:
>> D:/devel/workplace/unstable/qgis_head/build/qgssvnversion.h:1: error:
>> stray
>> in program
>> invalid to
>> ken
>> `define' d
>> oes not name a type
>> stray
>> in program
>> missing te
>> rminating " character
>> D:/devel/workplace/unstable/qgis_head/build/qgssvnversion.h:1:49:
>> warning:
>> backs
>> lash and newline separated by space
>> warning:
>> backs
>> lash-newline at end of file
>> D:\devel\workplace\unstable\qgis_head\src\core\qgis.cpp:13: error:
>> `QGSSVNVERSIO
>> N' was not declared in this scope
>> mingw32-make[2]: *** [src/core/CMakeFiles/qgis_core.dir/qgis.obj] Error
>> 1
>> mingw32-make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
>> mingw32-make: *** [all] Error 2
>> After that I had lookup
>> D:/devel/workplace/unstable/qgis_head/build/qgssvnversion.h it was
>> include
>> following line:
>> \ #define QGSSVNVERSION \"svn_rev_unavailable\" \
>> Best regards,
>> Byambaa Mendbayar
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
