[Qgis-developer] Library search paths on Linux/CMake
Magnus Homann
magnus at homann.se
Mon Feb 19 15:46:27 EST 2007
The best way to set paths to libraries on Unix is using LD_LIBARY_PATH
(when installed in non-standard place).
CMake gives another option, writing compile time search paths into the
binaries (and libraries). I have a small patch that includes paths both
for libqgis_core and for any other library in a non-standard place that
is used in compiling.
I'm not sure which is the proper way to do this, so I wont commit it.
The 'old' behaviour can be had by setting 'CMAKE_SKIP_RPATH' (adv.
option) to on in ccmake.
Above according to my tests with 0.8.
Index: src/gui/CMakeLists.txt
--- src/gui/CMakeLists.txt (revision 6632)
+++ src/gui/CMakeLists.txt (arbetskopia)
@@ -35,6 +35,11 @@
ADD_EXECUTABLE(qgis ${QGIS_APP_SRCS})
+SET_TARGET_PROPERTIES(qgis PROPERTIES
+ INSTALL_RPATH ${CMAKE_INSTALL_PREFIX}/lib
+ INSTALL_RPATH_USE_LINK_PATH true
TARGET_LINK_LIBRARIES(qgis
${QT_LIBRARIES}
qgis_core
Magnus Homann
magnus at homann.se
+46 702 399 558
