[Qgis-developer] Qgis 0.8.0 packages needed
Otto Dassau
otto.dassau at gmx.de
Tue Jan 2 06:19:24 EST 2007
On Sat, 30 Dec 2006 12:31:08 -0900
Gary Sherman <sherman at mrcc.com> wrote:
> On Dec 30, 2006, at 7:26 AM, Otto Dassau wrote:
> > BTW: I guess, there is a test for python 2.5 missing, which is used
> > in SuSE
> > 10.2. So I am not sure, wether python is included or not because it
> > is just
> > checked empty:
> You can determine if it is included by running the mapserver export
> tool from the QGIS File menu.
python wasn't used because of missing findutils (locate). No trying to add
python support a problem appears, maybe someone has an idea?
msexport_wrap.cxx: In function 'int SWIG_Python_ConvertPtr(PyObject*,
void**, swig_type_info*, int)':
msexport_wrap.cxx:1180: error: invalid conversion from 'const char*' to
'char*'
msexport_wrap.cxx: In function 'void SWIG_Python_FixMethods(PyMethodDef*,
swig_const_info*, swig_type_info**, swig_type_info**)':
msexport_wrap.cxx:2071: error: invalid conversion from 'const char*' to
'char*'
make[4]: *** [libmsexport_la-msexport_wrap.lo] Fehler 1
make[4]: Leaving directory
`/usr/src/packages/BUILD/qgis-0.8.0/tools/mapserver_export'
make[3]: *** [all] Fehler 2
make[3]: Leaving directory
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/usr/src/packages/BUILD/qgis-0.8.0/tools'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/usr/src/packages/BUILD/qgis-0.8.0'
make: *** [all] Fehler 2
error: Bad exit status from /var/tmp/rpm-tmp.2806 (%build)
thanks,
Otto
