[Qgis-developer] Windows native GRASS build
Radim Blazek
radim.blazek at gmail.com
Fri Jan 5 07:19:39 EST 2007
Thanks Marco!
-mwindows helped, attached is patch for Grass.make.in
and dbf driver Makefile. Similar change must be done in
Makefiles of all drivers. configure must be run because
Grass.make.in is source for Grass.make
It would be nice if this patch or something similar could be applied
to GRASS CVS head and 6.2 release branch.
Tim can you patch your GRASS in MSYS and create a new build?
We dont have to wait for 0.8.1 IMO because it does not include
changes in QGIS, it is just a new binary build.
Radim
On 1/3/07, Marco Hugentobler <marco.hugentobler at karto.baug.ethz.ch> wrote:
> Hi Radim and Tim,
> If the db driver is compiled with mingw gcc and you have the possibility to
> recompile it yourself, you may use the linker option -mwindows. I don't know
> of other possibilities to avoid the console (but I am no win expert too).
> Marco
> Am Montag, 1. Januar 2007 18:30 schrieb Tim Sutton:
> > Hi
> > > > 1) Every time a layer is added a black console box temporarily appears
> > > > and then disappears.
> > > It is known problem, db driver is exe and when it is started by spawnl()
> > > it opens Windows console for a while. I am not Win expert and I dont know
> > > how to avoid this. I have asked already in QGIS and GRASS devel lists.
> > Ok - I think its not a big problem for now.
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070105/a08ab3a7/Grass.make.in.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070105/a08ab3a7/Makefile.obj
