[Qgis-developer] Lib_Refactoring-branch merged (problem with
bulding python support)
Martin Dobias
wonder.sk at gmail.com
Wed Jan 10 03:52:41 EST 2007
basically python support has two stages in the build system:
- if Python includes and libraries are found, it will build mapserver
export tool
- if also SIP and PyQt4 are found, also python bindings will be built
SIP must be in version 4.5 or later and PyQt4 in version 4.1 or later.
These checks however are not yet in build system. Please check if you
have them in correct versions.
Your error happens during python bindings compilation when sip is
being run - it reports that QtCore/QtCoremod.sip is not found (should
be in /usr/share/sip). Can you check whether it exists?
Martin
On 1/10/07, Philipp Auersperg <phil at bluedynamics.com> wrote:
> Hi Martin!
> Thanks alot for this effort. Building with cmake (2.4.3) works fine
> under Ubuntu Edgy
> with apt-installed python, qt4 etc...
> But when I apt-install python-dev (2.4.3) python is included in the
> build process, but leads
> to an error. the cmake command itself passes fine, but the make
> process fails with the following output:
> ....[ 65%] Generating qgis_se.qm
> Updating '/home/phil/dev/qgis1/qgis/build/i18n/qgis_se.qm'...
> Generated 1004 translations (635 finished and 369 unfinished)
> Ignored 1282 untranslated source texts
> [ 68%] Built target translations
> [ 68%] Generating ../../python/run_sip
> Parsing SIP files for 'core' library...
> sip: Unable to find file "QtCore/QtCoremod.sip"
> Parsing SIP files for 'gui' library...
> Creating makefiles...
> Error: Unable to open "/home/phil/dev/qgis1/qgis/python/core/
> core.sbf": [Errno
> 2] No such file or directory: '/home/phil/dev/qgis1/qgis/python/core/
> core.sbf'
> make[2]: *** [../python/run_sip] Error 1
> make[1]: *** [python/CMakeFiles/python.dir/all] Error 2
> make: *** [all] Error 2
> Can perhaps somebody give me a hint?
> kind regards
> Philipp Auersperg
> Am 09.01.2007 um 04:23 schrieb Martin Dobias:
> > Hi all,
> > I'm pleased to announce that after many months all the changes from
> > refactoring branch were merged to SVN trunk (revision 6415).
> > As mentioned in previous thread, you should use new build system based
> > on CMake. That means that first of all you need it on your system -
> > version 2.4.3 or later is required. The only dependency of CMake is
> > C++ compiler so you don't have to worry about its dependencies.
> > (don't try to use 'configure' or 'autogen.sh' scripts - autotools
> > support is currently broken)
> > The preferred way how to compile it:
> > 1. configuration: cmake allows keep all build-specific files in a
> > separate directory. You can use e.g. directory called 'build' and run
> > cmake there.
> > mkdir build
> > cd build
> > cmake ..
> > If you have luck, cmake will detect everything for you. Otherwise
> > you'll need to run configuration utility.
> > - ccmake on linux/unix
> > - cmakesetup on windows
> > You have to pass it a directory as an argument where it should
> > operate. So if you're in the 'build' directory, just use: cmake .
> > There are several variables to tweak in configuration utility, you
> > might be especially interested in these ones:
> > - CMAKE_INSTALL_PREFIX - where to install it
> > - CMAKE_BUILD_TYPE - whether to build Release or Debug version
> > When everything is configured, just use make and make install as
> > usually.
> > To run QGIS, probably you'll need to set path to the qgis
> > libraries, e.g.:
> > export LD_LIBRARY_PATH=/home/wonder/qgis/lib
> > These instructions should suffice for basic setup - build system is
> > not yet fully mature so you maybe hit some problems. Please report
> > them to this mailing list and we'll try to help you.
> > Regards,
> > Martin
> > Qgis-developer mailing list
> > Qgis-developer at lists.qgis.org
> > http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
