[Qgis-developer] HOW TO COMPILE QGIS FROM SOURCE CODE FOR WINDOWS?
Martin Dobias
wonder.sk at gmail.com
Mon Jan 22 05:51:12 EST 2007
I recommend you to proceed first with downloading the sources and
compiling. Then you should learn how plugins work and how to write
them, take a look on this wiki page:
http://wiki.qgis.org/qgiswiki/DevelopersCorner
There's also section "Help on writing plugins" that you might find interesting.
Note: we don't use windows as a development platforms, so it's
possible that noone will be able to help you with some
windows-specific problems.
Martin
On 1/22/07, sijan ahamed <sijan4u at gmail.com> wrote:
> Hi,
> Thanx a lot for ur reply.....
> I would like to add new plugins to QGIS 0.8 on windows platform.And also
> wish to bring grass modules on grass tools plugin to tool bar for
> userfriendly.
> How should i proceed?
> I read many blog sites,but am not getng correct path...
> Hope you can help me...
> sijan
> On 1/22/07, Martin Dobias <wonder.sk at gmail.com> wrote:
> > Hi,
> > instructions for compiling 0.8 version are in readme_windows.txt file
> > in sources. However I would recommend you to download QGIS with
> > installer (unless you're going to do some development) as it's not
> > straightforward to compile it on windows.
> > plugin_builder.pl is just a simple script that creates sources for a
> > new plugin from template - no reason to use it unless you're
> > developing a new plugin.
> > Martin
> > > For adding extra plugins to qgis after installing in windows...require
> to
> > > run perl script in /../src/plugins/plugin_builder.pl.?
> > > right?
> > > but after installation,there is no such folder(src)in the installed qgis
> > > folder,.......solution?????
> > > cn i copy the src folder from qgis source code to qgis installed
> > > folder??????? and execute perl script....any probs????
> > > jaan
> > > _______________________________________________
> > > Qgis-developer mailing list
> > > Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
> jaan
