[Qgis-developer] cmake problems on RHEL/64bit
Martin Dobias
wonder.sk at gmail.com
Tue Jan 23 07:11:36 EST 2007
Hi Markus,
the variable QT_BINARY_DIR you're passing to CMake doesn't help. The
search for Qt4 starts by searching for qmake (or qmake-qt4) binary,
however QT_BINARY_DIR is a variable that the search macro sets by
itself. You may be interested to set path directly to qmake binary
which is used by macro to gather all information. Try setting
QT_QMAKE_EXECUTABLE to this file (e.g. /usr/bin/qmake-qt4 for me on
Ubuntu).
It uses also environment variable $QTDIR (not $QT4DIR) to search for qmake.
Hope that helps,
Martin
On 1/23/07, Markus Neteler <neteler at itc.it> wrote:
> Hi,
> I no longer manage to compile QGIS SVN HEAD on RHEL/64bit
> using cmake. Last week it magically worked. This is what
> happens:
> sh cmake_qgis.sh
> -- Found Proj: /usr/lib64/libproj.so
> -- Found Sqlite3: /usr/lib64/libsqlite3.so
> -- Found GEOS: /usr/lib64/libgeos.so
> -- Found GDAL: /usr/local/lib/libgdal.so
> -- Found PostgreSQL: /usr/lib64/libpq.so
> -- Found Expat: /usr/lib64/libexpat.so
> -- Using GSL from /usr
> -- Found GRASS: /ssi0/ssi/neteler/grass63/dist.x86_64-unknown-linux-gnu (6.3.cvs)
> -- Python libraries found
> -- SIP not found!
> -- PyQt4 not found!
> -- Python bindings disabled due dependency problems!
> CMake Error: Error in cmake code at
> /usr/share/cmake/Modules/FindQt4.cmake:857:
> MESSAGE Qt qmake not found!
> Current CMake stack: /hardmnt/bartok0/ssi/neteler/software/qgis_unstable/CMakeLists.txt;/usr/share/cmake/Modules/CMakeCInformation.cmake;/usr/share/cmake/Modules/CMakeCXXInformation.cmake;/usr/share/cmake/Modules/FindQt4.cmake
> -- Configuring done
> make: *** No targets specified and no makefile found. Stop.
> echo $PATH
> /usr/lib64/qt4/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:.:/ssi0/ssi/neteler/bin
> echo $LD_LIBRARY_PATH
> /usr/lib64/qt4/lib64:/usr/local/lib/qgis/lib/:/lib
> which qmake
> /usr/lib64/qt4/bin/qmake
> My meta configuration script contains:
> QGISTARGET=/usr/local/lib/qgis/
> GRASSBINS=/ssi0/ssi/neteler/grass63/dist.x86_64-unknown-linux-gnu
> QT4DIR=/usr/lib64/qt4
> export PATH=${QT4DIR}/bin:$PATH
> export LD_LIBRARY_PATH=${QT4DIR}/lib64:$LD_LIBRARY_PATH
> mkdir -p build
> cd build
> cmake -D GRASS_PREFIX=${GRASSBINS} -D CMAKE_INSTALL_PREFIX=${QGISTARGET} -D QT_BINARY_DIR=${QT4DIR}/bin..
> Any ideas? I don't know how to debug the problem with cmake.
> Thanks,
> Markus
> Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
> ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18 - 38050 Povo (Trento), Italy
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
