Fwd: [Qgis-developer] Fwd: windows build environment for QGIS
sijan ahamed
sijan4u at gmail.com
Wed Jan 24 05:30:01 EST 2007
*cpp/qgis/src/providers/wfs" -I"C:/dev/cpp/qgis/src/ui" -I"\ui"
-I"C:/msys/local/include" -I"C:/Qt/
/qgis/obj/moc" -I"C:/dev/cpp/qgis/obj/ui" -I"c:\Qt\4.2.2\mkspecs\win32-g++"
-o ..\..\..\obj\o\win3
.cpp
g++ -mthreads -Wl,-enable-stdcall-fixup -Wl,-enable-auto-import
-Wl,-enable-runtime-pseudo-reloc -
,c:\dev\cpp\qgis\qgis-release\lib\qgis\libgrassprovider.a -o
"..\..\..\qgis-release\lib\qgis\grass
ovider.o ..\..\..\obj\o\win32\qgsgrass.o
..\..\..\obj\o\win32\qgsgrassprovider.o -L"c:\Qt\4.2.2\l
\dev\cpp\qgis/qgis-release -LC:\dev\cpp\qgis/qgis-release/lib/qgis
-lqgis_core -lgrass_vect -lgras
ass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lgrass_I -lgrass_gproj
-lgrass_gmath -lgrass_gis -l
-lQtXml4 -lQtGui4 -lQtNetwork4 -lQtCore4
C:\MinGW\bin\..\lib\gcc\mingw32\3.4.2\..\..\..\..\mingw32\bin\ld.exe: cannot
find -lgrass_vect
collect2: ld returned 1 exit status
mingw32-make[4]: *** [..\..\..\qgis-release\lib\qgis\grassprovider.dll]
Error 1
mingw32-make[4]: Leaving directory `C:/dev/cpp/qgis/src/providers/grass'
mingw32-make[3]: *** [release] Error 2
mingw32-make[3]: Leaving directory `C:/dev/cpp/qgis/src/providers/grass'
mingw32-make[2]: *** [sub-grass-sub_Release] Error 2
mingw32-make[2]: Leaving directory `C:/dev/cpp/qgis/src/providers'
mingw32-make[1]: *** [sub-providers-sub_Release] Error 2
mingw32-make[1]:* Leaving directory `C:/dev/cpp/qgis/src'
mingw32-make: *** [sub-src-sub_Release] Error 2
C:\dev\cpp\qgis>
*i got this error after running make....*
*where i can get grassprovider.dll??????...i searched but some blog sites
given path which are not valid...*
On 1/23/07, Martin Dobias <wonder.sk at gmail.com> wrote:
> > I FOLLOWED THIS METHOD TO SETUP WINDOWS BUILD ENVIRONMENT FOR QGIS...BUT
> > ENCOUNTERED WITH SOME PROBLEMS IN THE MIDDLE...
> > 1.after runnng make---errors due to missing of"qgsconfig.h&qgssvnversion.h"
> > where i can get it????
> Those two files (and some more) are here:
> http://qgis.org/uploadfiles/msys/qgis-qmake-files.zip
> It's mentioned in the readme, please read it carefully.
> Martin.
> P.S. WHAT'S THE REASON OF WRITING IN UPPER-CASE? :-)
jaan
jaan
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070124/30f5c8f1/attachment.html
