[Qgis-developer] Mac OS X build of HEAD
Tom Elwertowski
telwertowski at comcast.net
Fri Jan 26 21:29:29 EST 2007
Gary Sherman wrote:
> I've compiled the latest SVN code (thanks to hints from Tom). I was able
> to run the application by double clicking on it in Finder. I thought I
> had read that this was not yet possible. Have these issues been
> completely resolved?
This was fixed by r6426.
> I also noticed some display problems. The title bar text ends up down in
> the map canvas area (see http://gisalaska.com/images/qgis_osx_display.png).
This first appeared with Qt 4.2. For qgis 0.8, it happens only when
launching from the command line and will correct itself when a layer is
added. For qgis 0.9, it happens both when double-clicking and launching
from the command line; it does not correct itself.
The problem has something to do with the relationship of the overview
canvas to something else; it may be the panning rectangle but I'm not
sure. If you set the parent of QgsMapOverviewCanvas to 'this' in
QgisApp::createOverview, the problem goes away. This is incorrect
however and may cause some other problem in the future.
Tom
