[Qgis-developer] export shape files from qgis
sijan ahamed sijan4u at gmail.com
Sat Jan 27 04:34:54 EST 2007
Hi...,
I am trying to copy paste SPIT plugin....and trying to implement export
shape files from qgis database ...
after reimplementing application logic...should i recompile code???
hope you will help me....
 On 1/27/07, Martin Dobias <wonder.sk at gmail.com> wrote:
> AFAIK it's unsupported. Use ogr2ogr utility.
> On 1/27/07, sijan ahamed < sijan4u at gmail.com> wrote:
> > Thnx...happy to c ur reply..
> > I created database using postgis....
> > connected qgis to database...
> > can u help me,how to export shapefiles.(as importing done using spit
> > plugin))
> > > Sorry, I don't use PostGIS, however I guess you first need to create
> > > the database (e.g. in Pgadmin3) and then use it in QGIS.
> > > Martin
> > > On 1/27/07, sijan ahamed <sijan4u at gmail.com> wrote:
> > > > i wish to connect qgis to database,so that i can import and export
> > > > files(eg:grass tool spit)
> > > > But qgis work on database created through POSTGIs(extension to
> > postgresql).
> > > > i am not able to create database using postgis???
> > > > hope you got ma problems???
> > > > On 1/27/07, Martin Dobias < wonder.sk at gmail.com> wrote:
> > > > > Hi,
> > > > > I'm sorry but I don't get what are you asking for. What database
> do
> > > > > you want to create and why?
> > > > > By the way, we all prefer discussion on qgis-developer list as
> also
> > > > > other people can reply and it's possible to search the mailing
> list by
> > > > > others.
> > > > > Martin
> > > > > On 1/25/07, sijan ahamed < sijan4u at gmail.com> wrote:
> > > > > > can u tell me the procedure to create database in qgis on
> windows
> > > > > > platform???/
> > > > > > jaan
> > > > jaan
> > jaan
jaan
jaan
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070127/1e75bd84/attachment.html
