[Qgis-developer] unknown cmake command "ADD_FLEX_FILES"
godofredo contreras
frdcn at hotmail.com
Fri Jul 13 22:30:10 EDT 2007
Hi:
I just update to revision 7070 and I´m getting an error when running cmakesetup the error is the following:
Cmake error: error in cmake code at c:/dev/cpp/qgis/src/core/CMakelists.txt:64: unknown cmake command "ADD_FLEX_FILES".
what I should change to get cmakesetup working?
Best regards
Godofredo Contreras
_________________________________________________________________
See what you’re getting into…before you go there.
http://newlivehotmail.com
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070714/61a502e1/attachment.html
