[Qgis-developer] QGIS 0.9.0 Preview 1
Otto Dassau
otto.dassau at gmx.de
Fri Jul 27 13:12:29 EDT 2007
to enable python bindings for debian I have following problems:
-- SIP is required in version 4.5 or later!
-- PyQt4 is needed in version 4.1 or later!
debian stable and testing includes PyQt4 4.0.1-5 and SIP 4.4.5-4. Wouldn't that
be sufficient?
regards,
Otto
On Fri, 27 Jul 2007 13:50:53 -0300
"Tim Sutton" <tim at linfiniti.com> wrote:
> Hi All
> Today I've tagged 0.9.0 Preview 1 as per our release plan at
> http://wiki.qgis.org/qgiswiki/ReleaseChecklist0.9
> You can check out a copy doing:
> svn co https://svn.qgis.org/repos/qgis/tags/Preview-0.9.0-1 qgis0.9.0Preview1
> This should bring into effect the following things:
> - string freeze for UI - if you are a developer please dont change
> any more UI elements or translatable strings
> - call for translators to update ts files
> - call for document managers to update docs based on new features in SVN
> - call for packagers to create preview binaries
> A source bundle for preview 1 will be made available soon.
> Now is the time we call on your help to produce translations, update
> documentation etc. You dont need to be a programmer to be of
> assistance - all you need to do is be willing to donate some time and
> have a computer.
> Note that automake and qmake build systems are completely removed and
> using cmake is the only way to build QGIS 0.9.0 preview 1. Please see
> the INSTALL document in the source tree for detailed notes for your
> platform. http://wiki.qgis.org/qgiswiki/BuildingFromSource Also
> contains updated build notes for all platforms.
> Many thanks for all who are pitching in to make this release happen.
> Best regards
