[Qgis-developer] 0.9 Python modules on windows
Barry Rowlingson
b.rowlingson at lancaster.ac.uk
Mon Jul 30 14:33:55 EDT 2007
Jesse Ayers wrote:
> I should have mentioned that I tried copying the \qgis folder into
> \site-packages as well, to no avail.
> I did not compile 0.9 myself, I was using the compiled version provided by
> Tisham in a post made on Sunday. I just tried to download it again,
> although both the NSIS installer and the zipped binary files appear to be
> corrupt now. I cannot install or unzip either file at this point. Further
> experimentation will probably have to wait until this evening when I get
> home.
>>In both the PATH and PYTHONPATH environment variables. Is one
>>of these paths or locations correct?
Are you sure these are being set right? In python, do:
import sys
sys.path
and check. I've not read the docs for PYTHONPATH on windows, but I cant
quite explain why:
C:\Documents and Settings\rowlings>set PYTHONPATH="c:\foo"
and then
C:\Documents and Settings\rowlings>c:\Python25\python
Python 2.5 (r25:51908, Sep 19 2006, 09:52:17) [MSC v.1310 32 bit
(Intel)] on win 32
Type "help", "copyright", "credits" or "license" for more information.
>>> import sys
>>> sys.path
['', 'C:\\Documents and Settings\\rowlings\\"c:\\foo"', ....
What the? Its appended what I wanted to my windows' 'home'
directory... I dont understand...
You can modify sys.path from within python if Windows refuses to play
sensibly :)
Barry
Barry
