[Qgis-developer] Custom raster drawing
Barry Rowlingson
b.rowlingson at lancaster.ac.uk
Tue Jun 12 07:52:16 EDT 2007
I want to display some rasters with a very specific colour scheme:
values from 0 to 0.9: gray (or maybe green. Something neutral)
from 0.90 to 0.95 : gray to yellow
from 0.95 to 0.99 : yellow to orange
from 0.99 to 1.00 : orange to red
its a sort of 'alert' system, the values are probabilities.
The current raster colouring system won't do it, so I've looked at how I
can extend it to do so. I've tried a couple of things:
I wrote a new Python class that extends QgsRasterLayer, and wrote an
overridden 'draw' method.
QgsRasterLayer has two draw methods - one with five arguments
(although in the docs this is called the '4 argument' method) and one
with three. The five-arg method does some calculation and then calls the
three-arg method. The drawThumbnail method also calls the three-arg
method directly. The three-arg method is then a big switch statement on
the drawing style.
What I wanted to do was to override the 3-arg method with my new
drawing code - it just has to paint on a QImage and return. But my
Python class method got called with 5-args. When I just called the
parent 5-arg method from my Python method it never called it again with
3-args. You can only have one method per name in a Python class, so
maybe there's some trick with SIP to get this to work. I couldn't. The
simple solution here would be to rename the 3-arg draw method in the C++
code, then I could override that and have it called. Let's call this
solution #1.
Solution #2 is to have a new drawing style, lets call it
CUSTOM_DRAWING_STYLE - then the big switch would have another case which
would then call drawCustomStyle - which would have a null definition for
a QgsRasterLayer by default, but which could be overridden by other
classes. I'd override one of the current drawing routines, probably
drawSingleBandPseudoColor, but they are private and so can't be accessed
from Python wrappers.
Solution #3 is to rewrite the raster drawing code to use renderers. I
think this is outside my timeframe though - I'd like to get this done in
a matter of weeks.
On top of all this there are still problems since to draw a raster on
screen I think you need access to adfGeoTransform, which is declared
private and there's no accessor method.
I know I've probably gone on about raster drawing before, but this is
the last thing on my Todo list for my project. I'm willing to spend time
on Qgis for this. Solutions #1 and #2 are pretty quick hacks that
shouldn't take long, #3 would require working with the rest of the team
to get it right. The problem with the private adfGeoTransform (and
possible other private members needed from Python) could be solved with
writing some accessor methods and associated SIP code.
Thanks,
Barry
