FW: [Qgis-developer] GRASS modules
Tim Sutton
tim at linfiniti.com
Mon Mar 12 14:06:06 EDT 2007
Hi Mende
Ok now I realise what you were talking about on skype. Yes I am going
to include those modules (they are not build with mingw by Lami the
zip is just sources. They are currently not working in 0.8.1 yet but
will be for the release.
Regards
Tim
2007/3/12, Byambaa Mendbayar <mendbayar_b at mongol.net>:
> -----Original Message-----
> From: Leonardo Lami [mailto:lami at faunalia.it]
> Sent: Monday, March 05, 2007 8:54 PM
> To: mendbayar_b at mongol.net
> Cc: 'Paolo Cavallini'; 'QGIS-dev'
> Subject: Re: [Qgis-developer] GRASS modules
> Hi all,
> Byambaa Mendbayar ha scritto:
> > Dear Paolo Cavallini and Tim Sutton,
> > Thanks a lot for you and other GRASS modules developers (Leonardo Lami and
> > Massimo DiStefano).
> > How can I see newly added GRASS modules which are announced by you? Those
> > new modules are already in SVN HEAD or SVN 0.8.0 (I mean 0.8.1)?
> Not again
> > How can I use http://www.faunalia.it/download/qgis_grass_0.tar.gz in my
> > development workstation? I have using following 2 environments which are
> > XUbuntu + QGIS dev deps and WindowsXP + QGIS dev deps.
> You can download the new collection of modules from
> www.faunalia.it/download/qgis/grass.zip and you can follow the
> instruction in the file README.txt-
> Pay attention: this modules needed more testing and some of them have
> problem with Windows!
> > Second:
> > I have trying to using "Raster map calculator" for simple operation like
> > Add, Sub and etc... My calculation is that:
> > r.mapcalc
> calcRes=(((raster_3x5.1 at ubap.sbd.15khoroo+raster_3x5.2@ubap.sbd.15khoroo)-ub
> > _sar_topo_3x5 at ubap.sbd.15khoroo))
> > Successfully finished
> > Note:
> > All layers which are used above calculations are same sized raster
> images. I
> > mean each image's extends are same to each other.
> > After that my output "calcRes" raster image is shifted, I mean outputted
> > image's coordinate was modified. Also outputted image's each pixel data
> have
> > same values, which are Minimum value: 850.655; Maximum value: 850.655.
> > What am I wrong? Is it my fault or system (GRASS modules) fault? How I
> check
> > my GRASS plugin's "Raster map calculator" modules work correct?
> I thin this is a problem of r.mapcalc command oin GRASS, write to the
> GRASS users list.
> Good work
> Leonardo
> > Best regards,
> > Byambaa Mendbayar
> > P.S
> > Thank you for reading my chaos mail, and your patient.
> > From: qgis-developer-bounces at lists.qgis.org
> > [mailto:qgis-developer-bounces at lists.qgis.org] On Behalf Of Paolo
> Cavallini
> > Sent: Monday, February 26, 2007 5:31 PM
> > To: QGIS-dev
> > Cc: Leonardo Lami
> > Subject: [Qgis-developer] GRASS modules
> > Hi all.
> > Thanks to Leonardo Lami and Massimo DiStefano we now have quite a few
> > GRASS modules added to the qgis-grass plugin. They have been tested and
> > no issue has been found. You can download it from:
> > It would be good if they could be added to the next release of qgis.
> > All the best.
> Qgis-developer mailing list
> Qgis-developer at lists.qgis.org
> http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
Tim Sutton
Visit http://qgis.org for a great Open Source GIS
Home Page: http://linfiniti.com
Skype: timlinux
MSN: tim_bdworld at msn.com
Yahoo: tim_bdworld at yahoo.com
Jabber: timlinux
Irc: timlinux on #qgis at freenode.net
