[Qgis-developer] Re: classification of rasters
Peter Ersts ersts at amnh.org
Mon Mar 19 08:33:55 EDT 2007
Marco Hugentobler wrote:
> Hi Peter,
> You are right,  mValueClassification.size() should be replaced with
> mCustomClassificationEnabled. My original idea was that it is either
> clipping/stretching or custom colormap.
Ok, great! I made this change already so it is currently either
stretching or custom colormap and should behave when you switch between
these options.
>> But I maintain the custom color map should display stretch values.
> I'm not sure I undestand what you mean. Do you mean that, if there is
> stretching enabled and custom colormap, there should be a combination of
> both?
> Maybe I can understand better with an example. Let's say we have a DTM and
> there is clipping and stretching enabled for values 500 - 800. But in custom
> colormap tab there are items 400 red / 600 green / 1000 blue and linear color
> interpolation. How would the application behave in such a situation?
So yes, I am suggesting there should be a combination of both. In your
example: the DTM values 500 - 800 get stretched from 0 to 255 for
rendering. In this case the color map could also be scaled so that  0 =
red 85= green and 255 = blue, but this is only done at during rendering,
the table values still stay the same (i.e. 400 - 1000). It may not
always make sense to do both but I am looking at if from a clarity and
usability standpoint for the user. If it is only going to be one or the
other, the we need to add quite a but more to the GUI to make it clear
that the user that they only have one option or the other.
-pete
Peter J. Ersts, Project Specialist
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Tel: (212)-496-3488 or (212)-769-5742
Fax: (212)-313-7295 or (212)-769-5292
Web: http://cbc.amnh.org
Visit the Indo-South Atlantic Consortium on Humpback Whales
Web:  http://www.isach.org
