AW: RE: [Qgis-developer] RE: FW: PostGIS driver in OGR doesn't support schemas
Düster Horst Horst.Duester at bd.so.ch
Tue Mar 27 08:43:28 EDT 2007
That's different to my assumptions. The direct import Postgis->GRASS via
v.in.ogr doesn't support schemas. OGR2OGR has only read support of GRASS
data. I think you should contact the GRASS list to mention the missing
schema support of v.in.ogr. I think that the missing schema support of
v.in.ogr is a fact of former ogr versions which doesn't support schemas.
Regards
Horst
-----Ursprüngliche Nachricht-----
Von: Byambaa Mendbayar [mailto:mendbayar_b at mongol.net]
Gesendet am: Dienstag, 27. März 2007 12:17
An: Düster Horst; 'cavallini'
Cc: 'qgis-developer'; 'Tim Sutton'
Betreff: RE: [Qgis-developer] RE: FW: PostGIS driver in OGR doesn't
support schemas
Hello Dr. Horst Düster,
Thank you very much for kind reply.
I have been using ogr2ogr tool for converting and transferring vectors
data.
It's working already fine here. But I want to directly import PostGIS
layer
into GRASS using QGIS's grass plug-in. Unfortunately it wasn't working
in my
own compiled QGIS. Please find attached screen capture.
My task is that:
Convert a PostGIS vector to raster using attribute values.
My solution is that:
1. Import PostGIS vector layer into QGIS's GRASS vector layer using
QGIS's
grass plug-in (v.in.ogr)
2. Rasterizing imported vector layer using v.to.rast which is transforms
GRASS vector map layers into GRASS raster map layer format
What you think about my own combination?
Please consider following I want to use QGIS for my primary tool.
Best regards,
Byambaa Mendbayar
________________________________________
From: Düster Horst [mailto:Horst.Duester at bd.so.ch]
Sent: Tuesday, March 27, 2007 6:20 PM
To: cavallini; mendbayar.b
Cc: qgis-developer
Subject: AW: [Qgis-developer] RE: FW: PostGIS driver in OGR doesn't
support
schemas
Hi Byambaa
OGR2OGR supports PostGIS schemas since version 1.40.
ogr2ogr -f postgresql "PG:dbname=... " shape -nln schema.tablename
should work.
Best regards
Horst Düster
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
Gesendet am: Dienstag, 27. März 2007 09:25
An: 'Paolo Cavallini'
Betreff: [Qgis-developer] RE: FW: PostGIS driver in OGR doesn't support
schemas
Dear Paolo Cavallini,
Thanks for reply to me. Also thanks for inform me.
I guess that OGR is already support for PostGIS schemas, only my
precompiled
GDAL/OGR isn't compiled for support PostGIS schemas. Is it possible? If
yes
do you know what configuration option should to turn on it when I
compile
GDAL/OGR from source, how can I build my own GDAL/OGR binary to QGIS
development environment?
Best regards,
Byambaa Mendbayar
-----Original Message-----
From: Paolo Cavallini [mailto:cavallini at faunalia.it]
Sent: Friday, March 23, 2007 11:47 PM
To: mendbayar_b at mongol.net
Subject: Re: FW: PostGIS driver in OGR doesn't support schemas
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Yes, I think this is a limitation of OGR (I may be wrong). I recall
having asked Frank Warmerdam, and he confirmed this.
In my view supporting schemas would be important, but apparently not
many people are interested.
All the best.
pc
> I was trying to import PostGIS vector layer to GRASS using grass
module
> which is called "v.in.ogr - Import OGR/PostGIS vector layer" command.
> Please see attached screen capture, it was appear when I import
> vector layer to GRASS.
> Best regards,
> Byambaa Mendbayar
Paolo Cavallini
email+jabber: cavallini at faunalia.it PGP: http://www.faunalia.it/pgp/
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGA/aJ/NedwLUzIr4RAl9EAJ4tm8zfIUCNBcIrSQWBI/6BPG+AuACgmmLr
CTItCx5FqgajePxzKv65oUs=
=5Llr
-----END PGP SIGNATURE-----
Qgis-developer mailing list
Qgis-developer at lists.qgis.org
http://lists.qgis.org/cgi-bin/mailman/listinfo/qgis-developer
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20070327/edec566a/attachment.html
