[Qgis-developer] QGIS crash on Mac OS X -- 0.8 release branch
Tom Elwertowski
telwertowski at comcast.net
Thu May 10 22:43:16 EDT 2007
Gary Sherman wrote:
> By default my OGR open dialog was set to UTF8. Trying other encodings
> didn't make a difference.
> Interestingly enough, Tim S. tried my binaries/libs on his box when this
> problem first popped up and he experienced the crash as well. I'm not
> certain how this relates to encoding. Is there a default somewhere for
> the system that is set wrong?
The file opens for me using both the default System encoding and UTF8.
Once you choose some other encoding, you can't get System back again. I
don't know if this has been a bug since QgsEncodingFileDialog was
created or a Qt3 to 4 adjustment that was never made. I will update
QgsEncodingFileDialog.
Meanwhile, you can delete the UI.encoding property in
org.qgis.qgis.plist to get the default System encoding back. Using the
System encoding might bypass the second call to
QgsOgrProvider::loadFields() which causes your crash.
Tom
