[Qgis-developer] CMake error on HEAD
Martin Dobias
wonder.sk at gmail.com
Tue May 22 17:25:29 EDT 2007
On 5/22/07, Mark Coletti <mcoletti at lychnobite.org> wrote:
> On Tue, May 22, 2007 at 10:51:00PM +0200, Martin Dobias wrote:
> > I haven't seen this problem yet. Will it help if you set the libraries
> > manually? Are they at some unusual place? CMake's FindQt4 module
> > searches for them with FIND_LIBRARY comand which should be able to
> > find them in standard paths.
> What's further odd is that I just went ahead and installed Qt4
> manually and cmake still gave same errors.
> I'll be happy to manually set them ... if I knew what to set them to. :-\
I can only help with my values:
QT_FONTCONFIG_LIBRARY /usr/lib/libfontconfig.so
QT_PNG_LIBRARY /usr/lib/libpng.so
QT_X11_m_LIBRARY /usr/lib/libm.so
QT_ZLIB_LIBRARY /usr/lib/libz.so
Martin
