[Qgis-developer] compiling xerces on mingw
Mateusz Loskot
mateusz at loskot.net
Thu Nov 1 12:32:16 EDT 2007
Benjamin Ducke wrote:
> Hi all,
> the GRASS binaries for Win also need Xerces-C support.
> I recall that Xerces is in the GDAL binaries for QGIS.
> Could you post some instructions on which version of
> the source code was used and how to compile it under
> MinGW? I'd be very grateful for this, as it seems
> to be somewhat complicated.
Benjamin,
I've never used MinGW myself, but I can confirm that I successfully build
GDAL 1.4.x and SVN with GCC 4.x using following versions of Xerces:
2.7.0
2.8.0
3.0.0 (SVN)
Here you can find some confirmation about GDAL & Xerces:
http://trac.osgeo.org/gdal/ticket/1799
http://trac.osgeo.org/gdal/ticket/1924
Summarizing, I believe you can use any of these 3 versions with GDAL & QGIS,
but I'd suggest 2.8.0 as latest stable version.
Here you will find instructions about how to build Xerces using MinGW:
http://xerces.apache.org/xerces-c/build-winunix.html
See section "Building on UNIX/Linux/Mac OS X platforms".
Cheers
Mateusz Loskot
http://mateusz.loskot.net
