[Qgis-developer] Advanced editing branch
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Thu Nov 8 03:05:39 EST 2007
Hi John,
> Are there more features from this branch that are not so
> obvious...?
There is also the possibility to snap to background layers and to set
tolerances for each layer to snap (to vertex, segment or both). Also, it is
possible to do topological editing, e.g. if a vertex is moved in a polygon
mosaic, the vertex of the adjacent polygon should also be moved.
Also, it is possible to activate 'remove polygon intersection' button. The
result is that if you digitize a polygon that overlaps others, the overlaping
areas are removed from the polygon.
You find this setting in settings -> project properties -> digitizing.
> A while back, I had put in a feature request for multiple vertex
> deletion. This is something that exists in OpenJump, but I much prefer
> Qgis and am hopeful that this will happen at some point. Marco had
> commented about the possibility of implementing this, but it was in
> the idea phase. This would be an immensely useful tool and could be
> extended to allow moves of a subset of vertices with the move tool in
> addition to multiple deletion if a vertex selection tool were
> developed. See this thread for a recap:
> http://www.nabble.com/Vertex-edits-and-selection-t4178483.html
I also think this is a useful feature. It is not implemented in the branch
because it is usually a big step from idea phase to implementation phase :-).
Please fill a ticket to the tracker with type 'enhancement' so that it does
not get forgotten.
Regards,
Marco
On Sunday 04 November 2007 17:20:23 John C. Tull wrote:
> Tom & Marco,
> First, the move and split feature tools are great. Those will be very
> useful. I had no problem using those in a test polygon on OS X after
> the geos fix. Are there more features from this branch that are not so
> obvious (map tools and digitizing prefs maybe)? I was not able to find
> documentation on the project.
> Also, will there be an undo feature. I recall someone discussing
> adding a program-wide undo feature. This would be good for handling
> editing goofs.
> I appreciate your great coding efforts. Good luck on the progress.
> Thanks,
> John
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
