[Qgis-developer] GRASS support in MSVC build
Jürgen E. Fischer
jef at norbit.de
Fri Nov 9 17:55:51 EST 2007
I have a MSVC build that supports GRASS.
Python support should already be in place given a python 2.5.1 install
with PyQt4 and SIP build with MSVC (IIRC that worked out of the box
using: python configure.py -p win32-msvc2005 & nmake & nmake install).
The archive http://www.norbit.de/~jef/qgis-grass-vc.zip contains
patches against QGIS and GRASS and a subdirectory
src/providers/grass/vc.
The GRASS patches only address the DLLS needed by QGIS to enable GRASS
support. When building QGIS with MSVC it'll build these from the
patched GRASS sources.
Please take a look. Should this be committed?
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
