[Qgis-developer] [QGIS Commit] SVN [godofredo] r7284 -
branches/ogr-plugin-branch/src/app
godofredo contreras
frdcn at hotmail.com
Sat Nov 10 12:35:15 EST 2007
Hi Martin:
I really appreciate your comments and all comments are
welcome. I really want to make a good work with the
ogr database access stuff.
In next week I will work in a document describing all
ideas and I will create a uml class diagram and with
your help and help from other qgis developers create a
better design that do not interfere with the library.Regards
Godofredo Contreras
> Date: Sat, 10 Nov 2007 13:59:32 +0100> From: wonder.sk at gmail.com> To: frdcn at hotmail.com> Subject: Re: [Qgis-developer] [QGIS Commit] SVN [godofredo] r7284 - branches/ogr-plugin-branch/src/app> CC: qgis-developer at lists.qgis.org> > On Nov 8, 2007 4:14 PM, godofredo contreras <frdcn at hotmail.com> wrote:> >> > The idea to keep qgsdatabaseconnectionbase and> > qgsconnectionmanager is to reuse> > this classes in the refactoring of spit and for the ogr plugin(layer cretion> > and utilities), If we move them to app> > how could we call that classes?> > Ah, I thought that you would implement that loading of layers directly> in application and not as a plugin. Right if they're moved out of core> lib they're not accessible for providers/plugins.> > Anyway, I still do not understand completely your design... and I fail> to find any information about it, how it will be bound to the rest of> QGIS and what will be changed.> > QgsConnectionManager does some managing of connections. This class is> not well designed as it depends on all supported types of connections.> Imagine that we want to add native oracle connection - in that case we> would need to modify also this class - that's not very nice. My> suggestion is to make it more generic: all provider-specific stuff can> be propagated to the Qgs*DatabaseConnection classes.> E.g. QgsConnectionManager::connect() would get just one parameter:> pointer to QgsDatabaseConnectionBase and will do the connection. Or> QgsConnectionManager::saveConnection() won't have hardcoded 'baseKey'> for every type of connection but will ask for it using 'mConnection'> instance. Does this make sense for you?> > > > Also I was thinking in using a similar aproach to> > QgsVectorLayerin QgsDatabaseConnectionBase but> > checking the code I saw that QgsProviderRegistry::instance() gives access> > just to provider class not to other> > classes compiled in provider(assuming that we move> > qgspostgresdatabaseconnection and qgsogrdatabaseconnection to their> > respective> > provider), do you know if there are a form to access other classes in the> > provider in runtime?> > I don't understand exactly the relation between Qgs*DatabaseConnection> and according provider so I don't know.> > I hope you don't take my complains as a bad critism of your work - I> just try to keep core library in a good shape.> > Martin
_________________________________________________________________
Peek-a-boo FREE Tricks & Treats for You!
http://www.reallivemoms.com?ocid=TXT_TAGHM&loc=us
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20071110/bb2014d3/attachment.html
