[Qgis-developer] First test build of raster branch for windows
Jürgen E. Fischer
jef at norbit.de
Sat Nov 17 07:40:33 EST 2007
Hi Martin,
On Fri, 16. Nov 2007 at 19:29:34 +0100, Martin Dobias wrote:
> > The only occurrences of "gdal" in the corresponding CMakeLists.txt is
> > within Windows conditionals so it doesn't surprise me that gdal isn't
> > linked in. The main and advanced-editing branches don't have this gdal
> > dependency; they link without gdal for me.
> > I will leave the solution to someone who is familiar with the
> > Python/CMake build process.
> Tom, could you try to make that section of CMakeLists.txt with gdal to
> be used always (i.e. not only with MSVC) whether that helps? I don't
> have a mac here so I can't test the difference...
Actually that was me that introduced GDAL linkage to
python/CMakeLists.txt and python/configure.py.in. I ran into it working
on the MSVC port and figured it would work elsewhere already.
I changed that now to be generic with r7440. Tested with MSVC and
Linux, but I don't have a mac either. But from the filenames I see in
CMakeLists.txt that should work there, too.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-0
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
