[Qgis-developer] linker command line too long for cmd.exe
Benjamin Ducke benjamin.ducke at ufg.uni-kiel.de
Mon Nov 19 08:43:35 EST 2007
Dear all,
I am trying to compile QGIS SVN head using MinGW and have run into a
serious wall:
When I 'make' the binaries, after the 52% compile step, I get:
Linking CXX executable qgis.exe
.. and after a few seconds an error message about the command line being
too long (uck!)!
Now, I am pretty sure that the problem originates in cmd.exe, as the
error message is German ("Die eingegebene Zeile ist zu lang.") and I am
on a German system.
I have tried replacing cmd.exe with a version from XP, which is supposed
to allow for longer commands, but to no avail.
I have put the QGIS sources into a very short path in order to shorten
the linker line but that also did not help. I suppose I could try
re-installing Qt into a shorter path. What do you think?
Has anyone had the same problems before?
Is there a replacement for cmd.exe that does not have this limitation?
Might there be a possibility to optimize the Makefile generated by CMake
so that it produces shorter linker command lines?
Where do I have to look to see the actual linker line being used? Does
CMake have something like a verbose switch, so I am not stuck with the
percentage display and can see what's actually going on?
I am grateful for any help on this one.
Best,
Benjamin
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
