[Qgis-developer] printing bugs
Steven Bell
botsnlinux at gmail.com
Thu Nov 22 10:12:58 EST 2007
> #737
> This is the Qt font issue - It should be fixed for all composer items
> except composer maps.
I realized I made a mistake here. #754 is the font bug, which appears to
affect Ubuntu. I don't have QGIS running on Windows at the moment, so I
don't know anything about the status of #737. Sorry for any confusion this
may have caused.
I've marked #758 as a defect, since this is normal behavior (unless you have
an extremely fast computer). The fix would be to replace the image with a
dashed box while dragging, instead of trying to render it along the way.
I'll try to look into the SVG stuff. It's currently unusable the way it is.
Steven
On Nov 22, 2007 8:49 AM, <lami at faunalia.it> wrote:
> Hi Steven
> I'm very happy that you work on mapcomposer troubles!
> I try to answer to yor request:
> > Here's what I've got for now. I apologize for not responding sooner.
> > #47
> > I can probably implement a raster legend, but I need some information
> on
> > what it should look like and what features it needs to have.
> We need a continuos (ex. for dtm raster) or category value legend (best if
> it is possible choise it) about all the raster load in the map canvas, Ask
> me if you need same other information.
> > #279
> > This bug exists because the point symbols are rasterized to be
> displayed
> > on the normal map. The fix (as I understand it) is to have the symbol
> > rendering function(s) manipulate the QPainter themselves, rather than
> > creating a pixmap which the parent draws. This will require some
> > significant changes, so 1.0 would be the earliest it would be fixed. In
> > the
> > meantime, there is a usable workaround - make the point symbols much
> > larger,
> > and use a small symbol scale in the composer.
> This bug is quite limitant, I hope it is'nt a hard work!
> Similar bug ticket: https://svn.qgis.org/trac/ticket/759
> > #454
> > This has some similarities to #279. Essentially, the problem is that
> > QPainter paints onto the composer canvas as if 1mm was 1px. It should
> be
> > fixable with Qt 4.2's QBrush::SetMatrix(). I hope to fix this as part
> of
> > the "major redesign", but that will probably be post 1.0. This can be
> > partially worked around by using a huge paper size.
> Idem
> > #590
> > This may be fixed now, as I suspect it was related to #548. Could
> those
> > who have had this bug re-test it?
> I'm going to test it!
> > #737
> Ok
> > Most of the bugs regarding SVG still exist. Qt 4.3 appears to have much
> > better support for SVG, so most of those bugs should be fixable now.
> about SVG output: https://svn.qgis.org/trac/ticket/822
> Here I'd like to show other map composer bugs:
> - about labels: https://svn.qgis.org/trac/ticket/754
> - about move objects in mapcomposer: https://svn.qgis.org/trac/ticket/758
> - about pdf output: https://svn.qgis.org/trac/ticket/823
> Hope this helps.
> Many thanks for your work!
> Leonardo Lami
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20071122/150f7e86/attachment.html
