[Qgis-developer] OT: qtdesigner problems: generated ui file not
valid for pyuic4
Matthew Perry
perrygeo at gmail.com
Thu Oct 4 16:29:45 EDT 2007
Hi folks,
Not a qgis question per se but I figured that someone on this list
might have encountered this and/or come up with a solution.
It appears that designer-qt4 is generating ui files that are not
compatible with pyuic4. I'm using straight ubuntu fiesty packages for
all the qt software.
Basic problem is that simply opening and saving a ui file in qt
designer (making no changes at all) messes up a previously valid ui
file. The example below shows the details.
Has anyone else encountered this issue on ubuntu? Am I doing something
obviously wrong here? Any ideas on how to fix this?
cp mainwindow.ui mainwindow.orig.ui
cp mainwindow_ui.py mainwindow_ui.orig.py
make clean
# generate the python file from the untouched ui file
pyuic4 -d -o mainwindow_ui.py mainwindow.ui
# OK; still runs fine
diff mainwindow_ui.py mainwindow_ui.orig.py
5c5
< # Created: Thu Oct 4 13:17:24 2007
> # Created: Wed Oct 3 09:44:22 2007
# open qt4 deisgner
designer-qt4 mainwindow.ui
# Change NOTHING, just file > save
# compile with pyuic4
File "/usr/bin/pyuic4", line 65, in <module>
error = generateUi(args[1], options.output, options.execute, options.indent)
File "/usr/bin/pyuic4", line 28, in generateUi
uic.compileUi(uifname, pyfile, execute, indent)
File "/usr/lib/python2.5/site-packages/PyQt4/uic/__init__.py", line
56, in compileUi
winfo = compiler.UICompiler().compileUi(uifile, pyfile)
File "/usr/lib/python2.5/site-packages/PyQt4/uic/Compiler/compiler.py",
line 71, in compileUi
w = self.parse(input_stream)
File "/usr/lib/python2.5/site-packages/PyQt4/uic/uiparser.py", line
524, in parse
actor(elem)
372, in createUserInterface
self.traverseWidgetTree(elem)
349, in traverseWidgetTree
handler(self, child)
165, in createWidget
240, in createLayout
249, in handleItem
158, in createWidget
self.stack.push(self.setupObject(widgetClass(elem), parent, elem))
133, in setupObject
self.wprops.setProperties(obj, branch)
File "/usr/lib/python2.5/site-packages/PyQt4/uic/properties.py",
line 189, in setProperties
self.convert(prop, widget))
line 156, in convert
return func(prop[0], **args)
line 116, in _sizepolicy
sizePolicy.setHorizontalStretch(values[2])
IndexError: list index out of range
# show differences in ui file due to saving with qt4 designer
diff mainwindow.ui mainwindow.orig.ui
17c17
< <property name="leftMargin" >
> <property name="margin" >
20,32c20
< <property name="topMargin" >
< <number>9</number>
< </property>
< <property name="rightMargin" >
< </property>
< <property name="bottomMargin" >
< </property>
< <property name="horizontalSpacing" >
< <number>6</number>
< </property>
< <property name="verticalSpacing" >
> <property name="spacing" >
45c33,35
< <sizepolicy vsizetype="Preferred" hsizetype="Preferred" >
> <sizepolicy>
> <hsizetype>5</hsizetype>
> <vsizetype>5</vsizetype>
64,65c54,55
< <width>405</width>
< <height>573</height>
> <width>353</width>
> <height>583</height>
72c62
75,87c65
< </property>
< </property>
< </property>
< </property>
118c96,98
> <sizepolicy>
140c120
< <height>25</height>
> <height>24</height>
Matthew T. Perry
http://www.perrygeo.net
"Never ascribe to malice, that which can be adequately explained by
incompetence."
