[Qgis-developer] Question about changing some code from QgisApp
to QGgsDbSourceSelect
Marco Hugentobler
marco.hugentobler at karto.baug.ethz.ch
Fri Oct 19 09:19:55 EDT 2007
Hi Godofredo
>thinking in usability it will be better if we
>could add multiple database layers without needing to close and reopen
QGgsDbSourceSelect
It is possible to add multiple tables from one database by selecting and
holding the ctrl key pressed. Or do you mean to add layers from multiple
databases with one dialog? If yes, how do you intend to change the gui
elements in the dialog?
>What do you think about this change, or it could be better to add the code to
manage ogr database layers
>in QgisApp::addDatabaseLayer()?
Maybe QgsDbSourceSelect should just give back a list of urls and provider
strings and QgisApp::addDatabaseLayer() just create the vector layers with
this information. That way, the assembly of the database urls for postgres-
or ogr-database layers could happen inside QGgsDbSourceSelect class. Does
that make sense?
Regards,
Marco
-----Ursprüngliche Nachricht-----
Von: godofredo contreras [mailto:frdcn at hotmail.com]
Gesendet: Di 16.10.2007 23:11
An: Hugentobler Marco; tim at linfiniti.com; gsherman at mrcc.com;
otto.dassau at gmx.de
Betreff: Question about changing some code from QgisApp to QGgsDbSourceSelect
Hi:
I'm working with QGgsDbSourceSelect dialog to unify access to spatial tables
(ogr and postgres).
The layers are added in QgisApp::addDatabaseLayer(), thinking in usability
QGgsDbSourceSelect,
but this needs that the calls of QgsVectorLayer and
QgsMapLayerRegistry::instance()->addMapLayer(layer);
have done from QGgsDbSourceSelect instead of QgisApp::addDatabaseLayer().
Best regards
Godofredo Contreras
Dr. Marco Hugentobler
Institute of Cartography
ETH Zurich
Technical Advisor QGIS Project Steering Committee
