[Qgis-developer] [Qgis-user] WMS Rendering Problems
Jürgen E. Fischer jef+qgis at norbit.de
Tue Oct 30 16:27:47 EDT 2007
Hi Tom,
On Tue, 30. Oct 2007 at 14:49:30 -0400, Tom Elwertowski wrote:
> This looks like a bug which was reported for Mac OS X a while ago. I
> have a patch which is essentially complete but I don't have the
> capability to build QGIS for Windows. If you or someone else can do a
> source build, I would be interested in finding out if the patch fixes
> your problem.
I'd like to test it.  Where's the patch?
> The fix I made is to remove the synchronous network request inside the
> draw event with async requests which must be completed before starting
> to draw. This also speeds things up for multiple WMS layers since all
> layers are requested in parallel rather than serially.
I did basically the same today, but I was still looking for a clean way
trigger a refresh after the WMS request completes inside the provider.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
