[Qgis-developer] cmake and ccmake usage - "Python bindings disabled"
icosa atropa icos.atropa at gmail.com
Fri Sep 14 22:57:36 EDT 2007
Thanks for previous ccmake+feisty+libgdal pointers.  I'm still getting
comfortable with cmake.  You pointed me in the right direction, and i
successfully built and ran 0.9.
I ran into some confusing cmake and ccmake behavior - using the
"ccmake" invocation, when I press "c" to configure my values, it
flashes messages including "Python bindings disabled due to dependency
problems" on the status bar... "e" doesn't show errors, and I can
still "g"enerate.  Is it possible to see (and respond to) these
messages in "ccmake"?
In cmake, what i'm assuming are the same messages go to the console.
I get I've verified the locations of the sip binary, python2.5
libraries, PyQt4, but I don't see where to specify PyQt4 location and
I still get
-- SIP not found!
-- PyQt4 not found!
-- Python bindings disabled due dependency problems!
any ideas?
best,
christian
On 9/11/07, Peter Ersts <ersts at amnh.org> wrote:
> icosa atropa wrote:
> > Finally, I have a question.  i'm using feisty, and during dependecy
> > install I had to make a package substitution with libgdal1.  Apt-get
> > tells me:
> Icosa, you are right about the libgal library, it is a bit different for
> Feisty. Here is my initial apt-get statement I use on fresh copies of Feisty
> sudo apt-get install subversion g++ qt4-designer qt4-dev-tools cmake
> postgresql-
> 8.2 sip4 python-sip4 python-sip4-dbg python-sip4-dev grass libgrass
> libgrass-dev
> libgeos-dev gdal-bin libgdal1-1.3.2-dev flex bison gsl-bin libgsl0-dev
> sqlite3
> libsqlite3-dev python-qt4-dev
> That should be all you need to get qgis to compile....
> > and again
> >   E: Couldn't find package libgdal1-grass
> I believe that you only need this lib if you are building grass from
> source also
> > so I use libgdal1-1.3.2-grass instead.  No problem, easy going until
> > compile-time.
> >   [ 25%] Building CXX object
> > src/core/CMakeFiles/qgis_core.dir/spatialindex/rtree/Statistics.o
> >   make[2]: *** No rule to make target
> > `/build/buildd/gdal-1.3.2/debian/tmp/usr/lib/libgdal1.3.2.so', needed
> > by  `src/core/libqgis_core.so'.  Stop.
> >   make[1]: *** [src/core/CMakeFiles/qgis_core.dir/all] Error 2
> >   make: *** [all] Error 2
> cmake is not finding the gdal library. From the build directory you can
> type:
> ccmake .
> in a terminal window and then you can set the correct path. You can also
> use a command line option to set the path to the gdal library. However,
> if you use the apt-get list above you should not have any problems.
> Hope that helps a little.
> -pete
> Peter J. Ersts, Project Specialist
> American Museum of Natural History
> Center for Biodiversity and Conservation
> Central Park West at 79th Street
> New York, New York 10024
> Tel: (212)-496-3488 or (212)-769-5742
> Fax: (212)-313-7295 or (212)-769-5292
> Web: http://cbc.amnh.org
> Web: http://geospatial.amnh.org
> Open Source, Open Mind.
> ...evolving through community cooperation to change the world bit by bit
Far better an approximate answer to the right question, which is often
vague, than the exact answer to the wrong question, which can always
be made precise -- j.w. tukey
