[Qgis-developer] Link issues on mac
John C. Tull
john.tull at wildnevada.org
Wed Apr 2 15:06:15 EDT 2008
Tom,
I started picking up those errors in my cmake step as well. I have
added it to my cmake alias for qgis. Currently, this is what I do for
cmake:
cmake -D CMAKE_INSTALL_PREFIX=/Applications -D GRASS_INCLUDE_DIR=/
Applications/GRASS-6.3.app/Contents/MacOS/include -D GRASS_PREFIX=/
Applications/GRASS-6.3.app/Contents/MacOS -D CMAKE_BUILD_TYPE=Release -
D GEOS_INCLUDE_DIR=/Library/Frameworks/GEOS.framework/unix/include -D
GEOS_LIBRARY=/Library/Frameworks/GEOS.framework/unix/lib/libgeos.dylib
-D PROJ_INCLUDE_DIR=/Library/Frameworks/PROJ.framework/unix/include -D
PROJ_LIBRARY=/Library/Frameworks/PROJ.framework/unix/lib/libproj.dylib
-D SQLITE3_INCLUDE_DIR=/Library/Frameworks/SQLite3.framework/unix/
inlcude -D SQLITE3_LIBRARY=/Library/Frameworks/SQLite3.framework/unix/
lib/libsqlite3.dylib -D CMAKE_OSX_SYSROOT=/Developer/SDKs/
MacOSX10.5.sdk ..
I've not tried building without grass, so have not run into the grass
issue you mentioned. I use William's frameworks on my Leopard system.
Cheers,
John
On Apr 1, 2008, at 11:16 PM, Tom Elwertowski wrote:
> With Xcode 2.5 (Tiger), I get the link to /Library/Frameworks but
> not to /usr/local; I had to add it myself. With Xcode 3.0 (Leopard),
> I get links to /Library/Frameworks and /usr/local/lib (but not the
> rest of local).
> I recently acquired a new Mac and also had build difficulties. I
> edited CMakeCache.txt to get around the problems so I could work on
> porting code to Qt4.4-Cocoa.
> To build qgis quickly on my new Mac, I installed William's
> frameworks and compiled expat, gsl and postgres myself with
> installation to /usr/local.
> When I run cmake, I get the following message:
> CMake Error: This project requires some variables to be set,
> and cmake can not find them.
> Please set the following variables:
> GEOS_INCLUDE_DIR
> GEOS_LIBRARY
> PROJ_INCLUDE_DIR
> PROJ_LIBRARY
> I manually set these in CmakeCache.txt to get past the problem.
> If I configure without GRASS, I get georeferencer compile errors
> because gsl headers cannot be found. If I configure with GRASS, the
> build completes successfully.
> georeferencer/CmakeLists.txt contains GSL_INCLUDE_DIR but the
> definition (-I/usr/local/include) doesn't appear in flags.make. When
> I manually add it to flags.make, the build succeeds. When
> configuring with GRASS, the definition still doesn't appear in
> flags.make but the headers get found anyway. I'm using William's
> GRASS which isn't in /usr/local.
> Tom
> William Kyngesburye wrote:
>> That happens automatically, behind the scenes, when you use an
>> SDK. The problem with the SDKs in Tiger (it's fixed in Xcode 3 for
>> Leopard) is that they don't have either /Library/Frameworks or /usr/
>> local symlinks to find user libraries and frameworks.
>> Add those symlinks, and linking (and includes) should start working.
>> /Developer/SDKs/MacOSX10.4u.sdk/Library/Frameworks -> /Library/
>> Frameworks
>> /Developer/SDKs/MacOSX10.4u.sdk/usr/local -> /usr/local
>> On Apr 1, 2008, at 7:57 PM, Tim Sutton wrote:
>>> Hi Tom & William (and anyone else who may know)
>>> I resinstalled my macbook yesterday and am compiling qgis against
>>> hand
>>> built libs now. The same procedure worked fine on my imac at work
>>> but
>>> here I get lots of errors like this when linking libqgis_core:
>>> ld: warning can't open dynamic library:
>>> /Developer/SDKs/MacOSX10.4u.sdk/usr/local/qgis_universal_deps/lib/
>>> libproj.dylib
>>> referenced from: /usr/local/qgis_universal_deps/lib/libgdal.dylib
>>> (checking for undefined symbols may be affected) (No such file or
>>> directory, errno = 2)
>>> Do you know why its concatenating that /Developer/SDKs/
>>> MacOSX10.4u.sdk
>>> onto the front of my lib paths? As always any hints will be most
>>> appreciated.
>>> Many thanks
>>> Regards
>>> Tim Sutton
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> [Trillian] What are you supposed to do WITH a maniacally depressed
>> robot?
>> [Marvin] You think you have problems? What are you supposed to do
>> if you ARE a maniacally depressed robot? No, don't try and answer,
>> I'm 50,000 times more intelligent than you and even I don't know
>> the answer...
>> - HitchHiker's Guide to the Galaxy
> Qgis-developer mailing list
